Question about Ovens
E3f1 code what does this mean
Oven will not heat
What is a error code F/19 mean?
That error means that the lower oven is not heating fast enough. IT should rise to over 150 in 5 minutes. Check the broiler and the baking coils for continuity. If they are ok then check the radiant heater in the convection fan housing.
May 12, 2015 | LG 30" Built-In Double Electric Convection...
I have a GE oven, model #JTP15W0W2W, serial #SS605844R that the bottom heating element does not work and the screen flashes F2. I contacted GE and they recommended I change out the bottom heating element,...
Ge should know their own codes. F2 for GE means oven control senses overheat over 600 degrees
Go here for code desciption . You should be able to fix youself
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes
best of luck
matt
Aug 15, 2011 | GE Ovens
What does F1 mean on the display panel on my Jenn Air gas oven? It won't allow me to heat up the oven, and the igniter is fine.
F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode or
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel -don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Hope this helps.
Jun 03, 2011 | Jenn-Air Ovens
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
Frigidaire pleb30t9fcc double oven -- top oven heats fine --- bottom oven does not heat up all the way
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
heatman101
May 14, 2010 | Frigidaire PLEB30T9FC Stainless Steel...
Oven not properly heating
heatman101
May 06, 2010 | Viking 30" Professional Select Built-in...
Says f1
F1 error code usually means that the oven temperature has exceeded 590 degrees. Usually this means that the oven temperature contol sensor ( or thermostat) has failed allowing the heating element to overheat the oven.
To correct this you will need to fit a new sensor. Sometimes the error code can mean a temporary glitch which may be cured by turning off the power for 30 mins and then resetting but if the problem persists then a new sensor is the answer.
Jan 07, 2010 | Kenmore Ovens
Ovens Logo
15 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
