Question about Kicker ZX1500.1 Car Audio Amplifier
What wrong when u got two 15" L3 n u hook up one sparker n it play turn up loud n it play then when u hook two sparkers cut on n off
When I hook up one L3 15" sparker I can turn up amplifier it plays good but when hook up bouth sparker it cut on in off
  • Kicker Master
  • 636 Answers
You are overloading the ohm load. Need the ohms on both speakers.
Posted on Jun 18, 2014
2 Suggested Answers
Bennytechkid
  • 99 Answers
SOURCE: i have a kicker 750.1 amplifier. I was playing it
I would say that your subwoofer Or speaker leads have shorted out...when the bass hits as you say it drives the amp hard but if it is trying to dump power onto a shorted speaker or speaker wires it will blow the output power transistors not to mention other vital components of the power amp...i suggest you test your speaker leads with a Multimeter on the ohm setting before connecting a repaires or another amp.. to make sure there is no short on the leads and that the resistance is around 4 ohms or so depending on how you have your drivers wired...but anything lower than 2 ohms will cook an amp! you can normally pick up a meter from anywhere for around $10..
Posted on Jan 14, 2010
How to light the Bosch TF250 pilot light
I believe this is a hydro-sparker pilot ignition then burner on when T-Couple/Flame Sensor acknowledges pilot lit.
W/O the signal feedback the Gas Valve will not open and light burner.
This is a Technician Service Job as you have insufficient knowledge to DIY this potentially dangerous LP/NG Control Valve/Sparker Assembly
I assume that lack of knowledge by your lack of a Manual for the Unit
You cannot force ignition on a hydro-sparker manually.
Sep 08, 2014 | Bosch Water Heaters
I have a 30 in jgp336 gas cooktop that fails to ignite when it clicks what is wrong, it worked a few days ago and suddenly stopped working
usually the spark module is not put back together properly.
1 make sure the spark unit is clean
2 make sure the gas jet is pointing towards the sparker
3 make sure there is no aluminum foil or other metal near the sparker pulling the spark away from the gas
Jul 06, 2014 | GE 30 in. JGP336 Gas Cooktop
Burner doesn't lite when turned on.while all the other burners turn on
I've seen that when a pot over boils and the ground connection of the sparker is fouled. Some sparkers are difficult to replace, and tough to clean the ground connection on them.
Nov 07, 2013 | Washing Machines
Sparker doesn`t work on wok burner, i have replaced it but still doesnt work, it does spark if you place a screw driver from sparker across to the ring
sparker sounds like its ok but its sounds like it needs to be adjusted a little so it can ground out to cause the spark you need
Apr 08, 2010 | Rangemaster Toledo 90 (Dual Fuel) Dual...
GE profile gas cooktop - sparker firing with knobs turned off?
replace your spark module
have you spilled liquid on the cooktop recently?
if yes let it dry for a couple of days and see what happens.
sometimes when you spill liquid on the cooktop it grounds out the spark module and it will continue to spark until it drys.
let me know if you need more help
Feb 15, 2010 | Cooktops
Model 790, propane, right rear will not light, piezo sparker works, seems like no gas to that one burner- ( the simmer )
i have a kenmore gas range when i turn front and rear burner no light but i can hear the sparker and smells the gas. any suggestions?
Jan 21, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Electric spark starter on one of the burner runs continuously
check the spark head on that particular burner first for dirt,they all need to be clean to recognize the flame after ignition and sense the flame to shut off the sparker module after ignition,and if not you will need to replace the spark module that fires the sparkers itself,but try cleaning sparkers and underneath where the wires connect to the sparkers first for contamination,its cheaper than starting to replace parts
Dec 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Only the infared burner does not ignite.
If you have a push button sparker the wire may be off or the sparker may be worn. You can check for spark when it is dark out. If you dont think you have spark then try to light the burner the "old school" way just hold a match or flame to the white area and then turn and hold the gas knob. If you can light it the old school way then its your spark. I would remove the sparker (unscrew the plastic nut on it remove the wire if its stll on) and test it on your hand. If the sparker works you will know because you will get a shock from the end of it. If you dont get a shock then you need to buy a new one. I hope this helps
Feb 02, 2009 | Dacor OB36 Gas Grill
Kicker ZX1500.1 Car Audio Amplifier Logo
54 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
