Question about VinoTemp (VT60GNV) Wine Cooler
Temperature goes too low
Temperature gets too low, freezes the wine and the digital display is l
Why does wine freeze?
Check for corrosion on the temp probe. The digital displays use thermistors to determine the temp so if the probe has dust on it it will change the resistance reading and tell the cooler that it is warmer than it is. All you can do is clean the probe, and if that doesn't solve the problem then the control or probe are faulty as they are usually one piece you will have to change it out. If you are mechanically inclined you can change out the temp control with an a19 abc24c remote bulb temp control from Johnson controls and that will last of the rest of your life.
Sep 05, 2014 | Danby DWC283BLS Wine Cooler
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
Thermostat on wine cooler
Well, I'm not sure what your actually trying to do, but the whole purpose of a wine cooler is to cool, not to freeze and the temperature should really get no colder than 34 degrees F.
Jun 19, 2012 | Refrigerators
Wine cooler too cold, compressor keeps running, temperature display is off
Let me first go over how a sealed system actually works that way when I tell you whats wrong you won't think I'm crazy. There are two sides to the freon system, known as the sealed system. The low side, where freon is in a gas form. In this form, freons temperature is at its coldest. Now, the freon can't just sit because movement is required for it to be cold. The high side does this by compressing the gas into a liquid,which pressure causes the temperature to rise, and forcing it through to the low side where it becomes a gas. So, with that said, the more freon in a sealed system the more pressure is applied, causing a higher temperature because less time as a gas. This is how they make wine coolers, walk in fridges, etc cool, not freeze. If you were to remove freon, the temperarture would get colder. Your wine cooler should have enough freon to prevent this from happening, and it doesn't therefor the freon has more time as a gas. Either you have a leak, or you've somehow knocked a freon line loose. It should have a year warranty on it.
May 18, 2012 | Refrigerators
My refrigerator keeps going into freeze mode instead of the temperature that i programmed into it.
if unit has a thermistat you need a thermistat if it has a digital diplay you need a control and thermistor. these are what controls the temps when they get to desired temp
Jun 03, 2010 | Danby Silhouette DWC512BL Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
VinoTemp (VT60GNV) Wine Cooler Logo
62 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Mari Severino
Mari Severino
Level 1 Expert
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
