Question about Sony Handycam CCD-TR517 Camcorder
Flashing code c:31:23 palyer will start but cuts off. rewind will start but cuts off.
    Champion:
  • 287 Answers
This is a capstan code you are getting. It just means the capstan motor which pulls the tape via a toothes belt and reel table ,has stoped when it shouldn't. Lots of things can cause this. I start by cleaning and dring the tape path then check reel torque and see if anything is binding the capstan. I have also seen a flex cable open up on these ls chassis that bring up this code.
Posted on Jul 28, 2009
Using a RESET button
  1. Locate the RESET button on the camcorder.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camcorder.
  2. Disconnect AC power adapter.
  3. Remove the battery pack.
  4. Remove the lithium button-cell battery.
  5. Move the POWER switch to the CAMERA position for 15 seconds.
  6. Move the POWER switch to the OFF position.
  7. Reinsert the lithium button-cell battery.
  8. Reconnect the AC power adapter or reinsert the battery pack.
  9. Turn on the camcorder.
If your camcorder is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required.
Posted on Feb 06, 2011
  • jk4bs Feb 06, 2011
    Sony Camcorders before the year 2000 like the TR517 have no reset button (1999)
    I put this 1st option in for those who have more current camcorders, for the TR 517 you must use the 2nd option
How to erase dictation
Hello Press and hold telephone and rewind at the same time for about 3 seconds the unit will start to rewind and ERRASE will be flashing on the display
Apr 10, 2014 | Lanier 260T Desktop Cassette Voice...
How do I erase the tapes on a Lanier VW-210
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Jan 13, 2012 | Lanier Audio Players & Recorders
What is causing my 1994 dodge Spirit to cut out while I'm driving?? I've changed the coil and that alleviated the problem for like an hour... now the dang thing is rite back to cutting out.... I...
How long since overall tune-up? Did you check for applicable trouble codes? You should be able to check some codes, yourself.
Cycle the key, on--off, on--off, on, then the check engine lite on the dash starts flashing, you count the flashes to get the codes. Your looking for two digit code, example, a code 24, is two quick flashes a slight pause then four flashes.
If I replace an ignition coil, I usually replace spark plugs and plug wires, also. Could be other issues besides spark?
Nov 01, 2017 | 1994 Dodge Spirit
My webcam can not take picture it says upgrade required flash player...what should i do?
Hi
Just download and install flash palyer to make your webcam works like adobe flash player.
Jan 11, 2011 | Computers & Internet
When I start the movie the screen is dark and there is no vertical hold on the cyberhome screen
ur palyer is progressive mode u cahnge normal mode.press and hold stop button on ur dvd palyer front panel
Jan 26, 2010 | Cyberhome CH-DVD 300 DVD Player
My car starts but cuts out when i try to... my car starts but cuts out when i try to put it in gear. runs fine when im driving.
Have you tried cycling key for fault codes? Turn ignition to on (not start) then off, then on, then off, then on, leave it on, and count flashes of check engine light.
flash,flash,pause, flash flash, is code 22. 3 flashes, pause, then 5 flashes, would be code 35, etc. See what you get, & get back to us with them if you need more help.
Oct 15, 2009 | 1988 Dodge Daytona
Lux 5000 vacuum cord will not rewind it is pulled all the way out need to disassemble
This rewind is not easy to work on, I rewound my Eureka with much persistance. The vacuum shop didn't want to tackle this.
It's easy to cut your fingers on the spring.
Apr 25, 2009 | Vacuums
What is flash palyer
how to enaable flash player on psp http://www.sony-psponline.com/ flash player is a form of video and animation
streaming
Jan 24, 2009 | Sony PlayStation Portable (PSP) Console
REQUEST
go to adobe.com, there it says, somewhere near the down right, download flash player
click that and the rest of the instructions are in there
Dec 08, 2007 | Macromedia Flash MX
Sony Handycam CCD-TR517 Camcorder Logo
545 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
