Question about Maytag PYE2300AY Electric Dryer
Our dryer ran for about half an hour and then stopped running I opened the door shut the door and you can hear the timer but when you go to push the button to start it it will not start. Any suggestions?
  • 867 Answers
Sounds like the overheat circuit breaker popped for safety. when the unit cools it will work again. most likely problem is your vent out is blocked, or lint filter full. once i found a birds nest on the exaust outside lol.
Posted on Jun 14, 2009
When I turn the dial on my dryer to preset drying time and pushed the button the dryer started and ran but after a half hour it was still at the same location as I had put it and the clothes were stil
Sounds like the dryer fuse-able link has opened. If this happens the timer will not advance and the heater will not go on. Check the schematic of the dryer to see where it is located. When located check the continuity, if open, that is your problem. They are located in places that are not easily accessible (usually).
Sep 21, 2014 | Dryers
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 11, 2013 | Amana Dryers
My dryer won't turn on at all. Can hear timer and I had the push start tested and is ok . any suggestions?
first test the fuseable link in the back its near the fan burner area on gas units on electric by the coil heater. let me know then we go from there
Nov 03, 2012 | Kenmore Dryers
What's wrong with my dryer & how do I fix it? Kenmore 70 series dryer won't shut off!! It stops when the door is open but won't shut off on it's own.
If the timer just keeps going past the next off and never shuts off then it could be one of two things. First, is the heating still on when door is opened? If it is then the electric heating element is broken in half and one half is getting neutral by laying against the metal heater case which will cause this problem. (assuming a electric dryer). If not then the timer is the culprit and check fleabay for NOS.
May 01, 2010 | Kenmore 62602 Electric Dryer
Won't shut off unless the door is opened
Usually the only thing that will stop the dryer is to open the door or turn the timer to the off position.
Nov 24, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Kenmore 110.96588210 Electric Dryer
you can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
Sep 22, 2008 | Kenmore 62602 Electric Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
88 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
