Question about Toys
2006 freightliner ecm trouble codes
Fault code bad hvac 146s 010 12 what part of system is bad ?
  • 272 Answers
SOURCE: mazda rx8 fault code p0410
The P0410 code refers to the (secondary air system) emissions system. The AIR pump puts air to the exhaust to lower emissions. It takes in outside air and pumps it through two one-way check valves into each bank of the exhaust.
About 90% of the time that this code is set, the one-way check valves have worn out or failed and allow water (which occurs naturally in the exhaust) back into the pump. In any cold climate, especially in climates with higher humidity, this water may be more excessive. The water partially fills the AIR pump, it can then freeze. When the PCM commands the pump on, if the pump is frozen it cannot turn, thus overloading the circuit and "popping" the fuse.
A code P0410 may mean that one or more of the following has happened:
  • Water may have collected in the AIR pump or the vent solenoid and frozen or corroded the pump
  • Blown AIR pump fuse due to freezing up
Possible solution:
This may be covered under the emissions warranty on the vehicle. If your vehicle is out of bumper-to-bumper warranty, check if the emissions warranty is still valid!
  • Replace the AIR pump AND one-way check valve
  • Test and clean the AIR pump AND test and replace the one-way air check valve
  • Replace the AIR pump inlet hose
  • Replace the AIR pump fuse (found under the hood)
It is really only an emissions issue and won't harm your car's engine ot drivetrain. It will however mean you won't pass emission testing if you live somewhere that tests for that like I do!
Posted on Jun 03, 2009
redbeard00
  • 957 Answers
SOURCE: 2006 dodge ram hemi 5.7 liter trouble codes 1404 a...
The check engine light is on to tell you that the ECU has detected a fault. The faults are stored as codes. The codes both have to do with a deficiency of exhaust gas going through the EGR valve. You will need to find out if the problem has to do with the valve, a leak, or the circuit.
Posted on May 22, 2010
e-Guru
  • 3917 Answers
SOURCE: fault code P0499 has be
Hi
P0499 Evaporative Emission System Vent Valve Control Circuit High. There is an electrical problem with the canister solenoid circuit. You need to replace the solenoid.
Try this first.....Disconnect the NVLD Assembly harness connector. Measure the resistance of the NVLD Solenoid coil. The resistance should be between 7.5 and 8.5 ohms. If not then you need to replace the NVLD Assembly.
Probe the wire side of that connector, wire color "white with dark green stripe" (power) and other side of tester to a GOOD ground, or negative power. Is the voltage above 1.0 volt? If yes. You have a short in the wiring .. Follow the wiring from the NVLD up to the engine compartment looking for the problem.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 05, 2011
  • 7 Answers
SOURCE: 2011 freightliner Cascadia with DD15. Fault code
BEFORE CONTECT ME DONT WORRY ABOUT IT 03452663007
Posted on Mar 26, 2011
  • 747 Answers
SOURCE: Fault code is P0183
this is the fuel temperature sensor a circuit high input reading
Posted on Jun 28, 2012
2012 freightliner cascadia DD15 fault code ECU 1... prior to the fault code the engine bogged down really bad and solid yellow and check engine light come on.
an answer from just answers reports this
ecu 1 fault means the engine ECM has an internal fault and needs to be replaced
most of the time with this code it is not the ECM itself but usually a wiring problem going to the ECm
there should be 2 fuses for the ECM either next to the ecm in plastic covers by a starter or in a plastic box
check all wiring going to and from the engine and battery grounds
especially the grounds
check for wires rubbed through and loose terminals
take it to a service dealer for a proper diagnosis as it costs money wasting time trying to find the fault yourself as a truck standing still is not earning it's keep
Jun 05, 2016 | Cars & Trucks
2012 freightliner cascadia engine code ECU 1. What does this mean
Ecu 1 fault means the engine EMC has a internal fault and needs to be replaced. Most of the time with this code It's not the ecm itself it's usually a wiring problem going to ECM. Their should be two fuses for ECM either next to ECM in plastic covers or by starter or in battery box. So you need to check all your wiring going to and from engine ECM (it's on drivers side of engine) and all your engine, starter, and battery grounds. Most of the time its a bad ground wire so take your time and check all over for any place that wiring could get rubbed through and all your connections are clean and tight. You would also want to disconnect battery negative while your doing this or it will log a bunch of other codes. Make sure all connection are corrosion free clean them as needed.
I have a 2006 Pontiac g6 gt and my heat or air will not turn on or rear defrost
You have a computer controlled HVAC system ! It has the capability of setting DTC'S - diagnostic trouble codes !
The HVAC control module is a non-GMLAN device that interfaces between the operator and the HVAC system to maintain air temperature and distribution settings. The battery positive and ignition 3 voltage circuits provide power to the control module. The HVAC control module during defrost mode will change the A/C compressor LED status from on to off. The control head displays recirc, outside air, A/C and rear defrost feedback status through LED indicators. The control head has a rear defrost request switch please refer to Rear Window Defogger Description and Operation in Stationary Windows for operation. The HVAC control head will display NO COMMUNICATION when checking DTCs or doing a vehicle diagnostic system check refer to Diagnostic Trouble Code (DTC) List - Vehicle and Diagnostic System Check - Vehicle in Vehicle DTC Information.
The rear window defogger system consists of the following components:
Body control module (BCM)
Heating, ventilation, and air conditioning (HVAC) control module
Rear Defog relay
Rear window defogger grid
Your probably better off taking this to a ASE certified repair facility ! You probably have bad Heater / A/C control panel . HVAC Control Module Malfunction
May 06, 2015 | Pontiac Cars & Trucks
I got a code p0446 and u1153 what is wrong
P0446Evaporative Emission (EVAP) Vent System Performance=ECM, PCM
U1153 Loss of Communications with HVAC
Mar 09, 2015 | Cars & Trucks
Bad 146s 010 12
"bad 146s010 12"...has to do with the blower fan (heat and a/c) is what info. I have found.
May 09, 2013 | Unknown Freightliner Century Class 120...
What is a bh164 fault code on an M2 freightliner?
2006 freightliner m2 code bh 164 don't star engine I don't now why !!!
Oct 10, 2011 | Cars & Trucks
18034 code,i think is a bad conection, in the TCM,but where is it.my car is a audi a4 2005
Trouble code identification:
VAG type 5-digit fault code 18034 = EOBD type P1626 fault code:
Fault location = CAN data bus, TCM - no signal
Probable cause = TCM trouble code(s) stored, TCM incorrectly coded, wiring, matching resistor in ECM.
Jan 28, 2010 | 2005 Audi A4
Toys Logo
339 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
