Question about Philips SpeechMike Premium LFH-3600 LFH-3610
Scanner is not scanning the numbers 1 &2
When using the scanner on the 3610 it does not recognize the numbers 1 & 2
My scanner will only scan bank 1 and 2
When your scanner is scanning normally (in only banks 1 and 2 at this point) just hit the number for the banks you want to scan. To remove a bank push that number again. Make sure it the scanner is actually scanning when you do this.
Regards, Tony
Apr 22, 2011 | Radio Shack Pro-82 Scanner
Can not scan to mac computer from hp c7280. What should I do? I need to know how to scan hp c7280 to my imac computer. I receive the message "refer to device documentation to troubleshoot." ...
There are multiple ways to use the scanner on your Mac. If your Mac recognizes the scanner as a device, then you can use the scan from the Mac using Preview or Image Capture apps (in your Applications folder). You can also use Picasa by going to the import function and finding the scanner and try it from there. If you are having issues getting the HP scanner to recognize the Apple device. Here is the official website for the download from HP. Apple drivers sometimes do the job of getting the scanner to be recognized, but the official drivers might do better.
Mar 02, 2011 | HP Photosmart C7280 Printer
I need extra memory for acer aspire 3610 and i want to know how many GB i can put
According to page 6 of the manual, your 3610 came with system memory 256/512 MB of DDR2 400 memory, and is upgradeable to 2 GB using two soDIMM modules.
You can see a list of sources for your memory here. Additionally, you could go to Crucial's site and perform a scan of your computer for suggestions of memory upgrades.
I hope this helped & good luck!
Nov 01, 2010 | Acer Aspire 3610 Notebook
I want to scan a photo to my computer with " Hp deskjet F4240 all -in-one"??
Open the lid on the HP scanner to reveal the scanning surface. Tthe scanning surface is the glass surface on which documents are placed for scanning.
  • Step 2 Put the picture face down on the scanning surface, using the positioning mark to set the picture. The positioning mark is normally an arrow and it indicates the correct placement of a document on the scanning surface for a good scan.
  • Step 3 Close the lid on the HP scanner.
  • Step 4 Press the "Scan To" button on the HP scanner and choose a format for the scan. "Scan to File" or "Scan to Email" are a couple of the choices. Press "OK" and your scan will begin. On your computer screen, a progress bar will let you know how your scan is going. Once the scan is complete, the folder where the file was scanned will appear on screen and you can click on it to ensure the quality of the scan.
  • or go to folowing link
    http://www.hp.com/united-states/consumer/digital_photography/organize_archive_photos/tips/scan_resize_share.html
    May 30, 2010 | HP Office Equipment & Supplies
    My Symbol LS2208 will not recognize Interleave 2 of 5.
    You will need to download the product reference guide for this scanner: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=165642940&stateId=1%200%20165644142
    once you have downloaded the file, go to the symbologies section, then the 2of5 section and scan the i 2 of 5 any lenght barcode
    this will fix your problem
    Thank you,
    Kim Ganoe
    kganoe@datexcorp.com
    Mar 25, 2010 | Symbol LS2208 Handheld
    How to program a bc855xlt uniden bearcat scanning radio
    Major Functions of Uniden BC 855 XLT Desktop Scanner
    RANGES AND MODES:
    29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
    MEMORIES & MEMORY SCANNING:
    • The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
    • To scan memory channels, press SCAN. To hold a channel, press MANUAL.
    • The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
    • Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
    • SPEED toggles between 8 & 16 channels per second in both scan & search modes.
    TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
    • Press MANUAL.
    • Press the channel number you wish to program using keypad.
    • Press MANUAL again.
    • Enter the desired frequency using the keypad.
    • Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
    • To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
    • To lock out channel from scan, select it & press LOCK OUT. Same deselects.
    PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
    TO SELECT CHANNELS MANUALLY:
    • Press MANUAL.
    • Press desired channel number on keypad.
    • Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
    TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
    TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
    • Press MANUAL.
    • Enter the lower frequency limit.
    • Press LIMIT.
    • Enter the upper frequency limit.
    • Press LIMIT.
    • Press SEARCH.
    I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
    http://uniden.com/pdf/BC860XLTom.pdf
    For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
    www.RadioReference.com
    BillB
    Jan 19, 2010 | Uniden BC895XLT Base Scanner
    I scan a document and then I click on
    I suppose you should have some software running on your system to accept the file.
    Check the user guide.
    Scan an image
    You can start a scan from your computer or from the HP All-in-One. This section
    explains how to scan from the control panel of the HP All-in-One only.
    To use the scan features, the HP All-in-One and computer must be connected and
    turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software
    (Mac) must also be installed and running on your computer prior to scanning.
    ● On a Windows computer, look for the HP Digital Imaging Monitor icon in the
    Windows system tray (at the lower right side of the screen, near the time) to verify
    the software is running.
    HP All-in-One overview
    Note
    Closing the HP Digital Imaging Monitor icon in the Windows
    system tray can cause the HP All-in-One to lose some of its scan
    functionality. If this happens, you can restore full functionality by restarting
    your computer or by starting the HP Photosmart Software.
    ● On a Mac, the software is always running.
    Tip You can use the HP Photosmart Software (Windows) or HP Photosmart
    Mac Software (Mac) to scan images, including panorama images. Using this
    software, you can also edit, print, and even share your scanned images. For
    more information, see the onscreen Help that came with the HP All-in-One.
    To scan to a computer
    1. Place your original print side down on the left front corner of the glass.
    2. Press Start Scan/Reprints.
    A preview image of the scan appears on your computer, where you can edit it.
    3. Make any edits to the preview image, and then click Accept when you are
    finished.
    Dec 19, 2009 | HP Photosmart C3180 All-In-One InkJet...
    Can"t get it to scan. not on wireless.HP 4780 photosmart
    You are saying that the printer/scanner is directly connected to the computer?
    You need to start checking the physical connection. Make sure that you can print to make sure that the printer is being recognized by the computer.
    Second, try uninstalling and reinstalling the printer/scanner driver using the CD that came with it. Most of the time, it's the driver that causing the problem.
    Hope this helps and have a good day!
    Nov 27, 2009 | HP Photosmart C7280 Laser Printer
    I have a Regency Touch K 100 ( NO MANUEL ) Scanner
    I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
    http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
    For $5 it might be worth it.
    For all of your scanner needs: ScannerMaster
    Nov 17, 2009 | Radio Shack Radio Communications
    Scanner on Sharp AR-M350u is showing NG800000 and is not sending scanned items.
    This mistake NG800000 offset scanning device.
    1 Try reinstall a driver on local on cord USB
    2 Remove glass of the scanner and check displacement scanning device, it must softly move. Smazhte nodes mask, продуйте the sensors, check join a wire. Do Not use the long cord USB gets lost the signal, appear the hindrances.
    Write, help. Good luck
    Jun 22, 2009 | Sharp AR-M350U Copier
    Philips SpeechMike Premium LFH-3600 LFH-3610 Logo
    265 people viewed this question
    Top Philips Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
