Question about Philips DVP3020 DVD Player
NO PICTURE WITH VIDEO
NO PICTURE ON THE TELEVISION ONLY SOUND FROM THE DVD
I get a picture on my DVD, but no sound, I've asked this question twice now.,
There are a limited number of television and audio engineers that give there time free of charge to help others.
Disconnect the television and the DVD player overnight to reset.
Are you using surround sound? Unplug it and connect direct.
Remove the HDMI cable and turn it around. Check the mute button on the television.Check settings in the DVD settings and the television for 'video only'.
Jun 23, 2017 | Televison & Video
I have a JVC HD 52g787, the sound works but no picture, The tv comes on, but the blue light just blinks, then cuts off, I have sound no picture
The problem is usually from the power or the Y sustain at the left or right side of the display when one of the large capacitor or heat sync on the capacitor even the flat power cable connection it to a main power board needs to be checked too, if the fuses on the board are blown it will need to be replaced
But after replacingthe fuses and the capacitors and still no solution,youwill need to replace the all board ..
You can also trouble shoot first before going to the board of the TV..
How to Troubleshoot an LCD With Sound But No Picture
It can be overwhelmingly frustrating when an electronic device as expensive as an LCD television set starts having problems. Luckily many of these problems are easily troubleshot. While being able to hear sound coming from your LCD television but seeing no picture may seem serious on the surface, fixing the problem involves checking a few different settings to make sure everything is set properly
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jul 17, 2011 | JVC HD-52G886 52" Rear Projection HDTV
I have a Denon AVR 1707 reciever. I am trying to connect my dvd player through RGB cables. The sound works just fine when i turn the reciever to dvd but there is no video. I have the component 2 set to dvd...
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
May 25, 2011 | Denon AVR-1707 Receiver
Hooking up to the television s-cable and two audio jacks. I have a picture of the dvd but the sound comes from the television program in the background
The S Video cable and the two audio cables should be plugged into the same av input on your television. It sounds like the sound cables for your cable box or satellite tv box are plugged into the television where the two audio cables for the DVD player should be.
May 05, 2010 | GE 1106P DVD Player
I am receiving no picture when I play the dvd
check cables.check for video mode on remote
Jul 08, 2009 | Televison & Video
No sound or picture but menu comes up
Check video source like DVD Player has power, check connecting cords, cable connections etc.
when TV gives menu on screen that means TV is fine and problem could be hooked video signal items.
Apr 15, 2009 | Hitachi 51F59 51" HDTV Projection...
Samsung TXJ2754 (27") DVD issues (Sound but no Picture)
Assuming you have picture on the TV when hooked up to cable, antenna or satellite I would take the DVD player to a friends house to see if it worked on their set (using your cables of course). If you can't get a picture on your TV no matter what, then it could be either the Jungle IC or EEPROM IC inside the set. Since it displays "No Video Signal" on the screen, that leaves out the High Voltage section of the TV. My main suspicion would be the video cable or settings on the DVD or TV.
Jan 02, 2007 | Samsung TXJ2754 27" TV
Sound but no picture
try making sure that the video cord is plugged in to the video out port on the dvd player and that the other side of the video cord is plugged in to the video in port on the tv
Nov 27, 2006 | Philips DVD727 DVD Player
Philips DVP3020 DVD Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
