Question about 5000RS-2W Remote Starter with Full-featured Alarm two 2-way 5 button
My remote will not start my car
The remote is not starting the car and does not say arm
  • 4 Answers
Have you checked to see if the batteries are fresh in the remote? Sometimes the remote will act up and not lock or start the car when you want it to. If the batteries are fresh I would suggest seeing about getting a new remote or take the remote in to the dealership and see what they can do about it. There should be a troubleshoot guide in the car for this or you could probably find out more online. http://www.autodream.ca/shop/c/80/car-starter-calgary http://www.autodream.ca/shop/c/80/car-starter-calgary
Posted on May 08, 2015
94 dodge intrepid alarm problem remote will not dis arm new batteries lights flash horn beeps cannot start car any way to disable
Hi, if the alarm is armed the car not going to start,it might start and shut right back off. Have you shut all doors and hood down , take your key and lock and unlock car this should disarm alarm system.If dont work on driver side try passanger side. You might have remote reprogram. and if none of this work for you if you can stand the noise put key in switch and turn to run and leave it on for 30 mins. If i can help you futher just re post.
Thanks dodge tec
Jan 04, 2011 | Dodge Intrepid Cars & Trucks
2002 VW Cabrio alarm problem: alarm will not un-set. Door will not lock using the key OR the remote. Hitting "alarm off" button on remote, it unsets, then arms again immediately. With engine...
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
Nov 08, 2010 | 2000 Volkswagen Cabrio
Mts mode for preset manual trans auto start function enable,does not allow car to start, instead the park light blinks seven times and give an error tone ... Thank you
There is a sequence necessary to set the Viper every time you exit the vehicle: park the vehicle, put in neutral, place foot on brake, set parking brake,remove foot from brake, remote start vehicle with remote, remove key (vehicle should remain running), exit vehicle and close door, arm the alarm with remote (vehicle should shut down). The system is now set for MTS remote start. Test the system by remote starting the vehicle now (it should remote start at this point). If you open any door after the MTS remote start has been set, you will have to do the programming sequence again.This is a safety feature because something may have changed, i.e. parking brake released when the door was opened. You have to do this sequence each time you park the vehicle if you intend to use the remote start feature.
If this does not work, there may be an issue with the installation, i.e., the door trigger connection. Using dome supervision as a door trigger won't work because during the arming portion of the above mention programming sequence(when the vehicle shuts down), the interior lights will illuminate and the Viper will read it as a door opening. So, actual door trigger wires must be used.
Oct 23, 2010 | 5900 SST 2-Way Security System / Remote...
1996 Nissan Maxima - unlock car, anti theft alarm went off and car won't start. Got new battery, battery was dead, put in new battery, anti theft alarm still going off and car won't start. Please help
If the antitheft system is armed and isn't recognizing the key for starting, the dealer should be the next place it should be towed for reprogramming the key to the computer.
Oct 12, 2010 | 1996 Nissan Maxima
Spy 5000m remote start issues
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
May 05, 2010 | Brand Remote Start/keyless/car Alarm Very...
Installed. Arm the car locked. About 2-3 hours
You must change the doors trigger connection if you have a negative input change it to positive input or vise versa and try. I’m sure that this is going to end your problems or the smart way is, take it back to Best Buy
Jan 08, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
2007 Saturn Aura; when trying remote start horn beeps three times but doesn't start. I've replaced battery. Other functions work fine - door locks, trunk opens, alarm arms. Other key fob works fine.
press the lock button on the remote then press the remote start button. if this does not work check remote start status using steering wheel buttons
Jan 03, 2010 | 2007 Saturn Aura XR Sedan
2005 Grand Prix remote start causes alarm to sound.
remote start systems have a dis-arm alarm output wire ... this must be connected to the OEM alarm disarm wire ... your installer needs to service it.
May 08, 2009 | OEM Systems Vehicle Parts & Accessories
Viper won't remote start and arm/disarm only works sometimes
Greetings Microluv,
Simple question, have you changed the battery in your remote lately? I was having similiar issues with my remote start and it was a simple matter of changing the batteries in the remote.
I figured lets eliminate the easy stuff first. :)
Dorothy
Go Ahead. Use Us.
Jul 07, 2008 | Viper RCVGC022 Remote Control
5000RS-2W Remote Starter with Full-featured Alarm two 2-way 5 button Logo
100 people viewed this question
Top Scytek Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Scytek Vehicle Part and Accessory Expert? Answer questions, earn points and help others
