Question about Haier HSU09XCA 9000 BTU 10 SEER Rating Cooling Only Mini Split Air Conditioner With Remote Control
Outside unit why does the unit keeps freezing up?
  • 83 Answers
Most probably you need refrigerant re-charging. This is one of its markers.
I hope it helps.
Posted on Jun 14, 2009
Hi, our outside vent keeps freezing, ant suggestions on this issue? Thanks for your time.
What equipment is this? Are you running a/c with temps below zero outside? Need a little more info.
Jan 11, 2015 | Heating & Cooling
Dca213d window unit keeps freezing is it thermostat?
Check for badly bent fins or obstructed/dirt impacted fins on the outside of the unit. Could also be low on gas. Try setting the t/stat to various settings see if its turning off/on at higher settings, if it does most likelt stat is OK. Also make sure you drian is clear.
Aug 12, 2014 | Carrier Heating & Cooling
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
Ac unit in the house keeps freezing up, not a window unit, central unit. The entire part inside keep freezing up, making knocking noise, and not blowing cool air. The out side part is fine, no problems...
There is a coil out side in the unit , it needs cleaning, there is an acid that is used to clean it. Its an easy job, pull the top open and use a stick or something to keep it up so you can spray the coil, with the unit off let soak 10 mins then spray wash with water hose. done
Sep 29, 2013 | Heating & Cooling
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
I am not sure if it is a problem.....we recently bought a house with the above heatpump in it. We have noticed lately that the inside unit (not the outside unit) developes a layer of ice on it on really...
If it works fine during the heat of the day, but as soon as it cools down, it freezes up, then you may have a low refrigerant charge. The other things you may check are the indoor filters to make sure they are clean, and check if you are getting good air flow through the vents. Bad air flow can mean you have a dirty evaporator coil if the filters are clean. If the above checks out ok, then you will have a low refrigerant charge and need a technician to come out and charge the unit. What happens is the low charge will cause the pressures/temps to drop inside the unit. When its hot enough outside and warm enough on the inside of the house, its enough to keep it from freezing, but as soon as the outside/inside temps drop, the refrigerant drops below the freezing point and starts to freeze. As for asking if its a problem, definitely. Hope this helps and good luck!
Jul 02, 2011 | Heating & Cooling
My lines are freezing and the ac works sometimes and sometimes it doesnt. How do I avoid the lines from freezing
you need to check your filter to start with if thats good make sure all you vents are open and your returns are free from abstruction
Aug 25, 2010 | Honeywell Heating & Cooling
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Goldstar R1804H
well u should take it out the window and dran the water out unite thwe water is gone then put it back ang if u still see that its freezing try it again and then put it one and u my have to do this offin to keep it from freezing
Jun 28, 2008 | Goldstar R5050 Air Conditioner
Heating & Cooling Logo
182 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
