Question about Toshiba SD-3109 Multi-disc DVD Player
Disc Jammed So i put in a dvd, watch the movie, open up the tray.  The disc was not there, and it made a weird sound. So i guess that maybe if i slide the tray in again it would come out. So the dvd was stuck in the dvd player but can't come out in the tray. So i did a bunch of discs skips to see if it'll slide into place. didn't work. I did this a repeated times, and now the tray won't even open. what do i do? how do i get the disc out?
  • 537 Answers
The best way to get your DVD out of the player will be to open up the unit with a screwdriver. Be careful to make sure you find all the screws and make sure if they are different you note which hole they came from.
If you feel uncomfortable with opening up the unit yourself, take it into a service center.
Posted on Oct 30, 2007
DVD player makes grinding sound and doors don't open
You may have a stuck DVD in the player. Most DVD players have a small pin type hole in the front where you can inser a paper clip to manually open the tray. Otherwise, you have to remove the cover of the drive to actually see what is happening. support hp com Maybe this link will be of some assistance.
Mar 01, 2015 | Televison & Video
I'm trying to watch a movie on my coby portable DVD player and every time I try and watch a movie it just says invalid disc and it makes weird sounds.
If there is no TS-Folder showing in a computer then it is not a DVD Disc. The disc could be badly scratched, ie the noise. There are many theories and one I've heard but not try is putting nail polish over the disc the freezing overnight, defrost then wipe outward a from the centre. The DVD player may be out align then should be looked at or possibly cheaper to buy a new player. Hope the info was useful, good luck ;)
Sep 29, 2012 | Televison & Video
I insert a movie from the video store in the dvd player Zenith DVC2550.It got stuck in back and turn table was rotating without picking up the disc. I had open cover to remove the disc. I manage to close...
It sounds like you jammed the door gear which must be closed prior to playback. You can try to take the cover off again and cycle the insert mechanism but if you put much force on it the machine may be destroyed...
May 05, 2011 | Zenith Televison & Video
Xbox 360 elite console makes 2 weird noises and says open tray when putting in any to fix it
I've fixed open tray errors before, and if you are sure the problem is with the 360 and not the disc, it means you need to open the dvd drive and slide the laser over once or twice (at least based on my experience). BE CAREFUL. The mechanism that allows the laser to move around and read the disc is probably jammed.
Mar 20, 2011 | Microsoft Xbox 360 Console
Opens in middle of game play and makes weird scretching noise
well im havin about the same problem and it sounds like you need a new dvd drive for your 360 itll cost you about $25
Jun 02, 2009 | Microsoft Xbox 360 Console
5 cd changer tray wont open
just opened the dvd player..took out the jammed cd and it's working properly now...saved me 55$ for a check or was advised to buy a new one costing 400 odd $!
Jan 21, 2009 | Philips CDC775 5-Disc CD Changer
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Not closing
Hello, with mechanical problems with sophisticated systems of gears etc, the only way thate one can fix it is if you send me a digital picture yourself. To access the inside of the DVD player, you will have to get a handyman to open the DVD player up with a screwdriver, by undoing some screws which hold the cover to the player itself. Then, with the player's circuit boards (The Green/brown Boards with weird components on it) showing, take around 5-6 photo's of the loading tray and the playing tray.(Where the disc is when watching a movie)In the time being, open the layer's cover as instructed before, and look at the inside of the tray for any broken plastic, debris or anything stopping the tray from opening. Good luck!
Oct 05, 2007 | Sony DVP-NS305 DVD Player
Even when the DVD is in the tray correctly, it says "No Disc"
I had a similar issue and now mine is opening closing opening and then powering off?
Mar 18, 2007 | Toshiba SDK615 Multi-disc DVD Player
Toshiba SD-3109 Multi-disc DVD Player Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
