Question about Radio Communications
My he'd sx-907 headphones won't charge what do I do?
I plug them into charger but they are not charging
SOURCE: navman won!t charge from in
Your Navman will not run in car unless the output on the charger is 1000ma or 1a. you need to buy a genuine charger, motorola phone chargers do not have the output to run the unit
Posted on Aug 26, 2008
  • 1514 Answers
SOURCE: Nuvi will not charge when plugged into car charger
  1. Check that the cigarette lighter socket is working. If not it may be a fuse blown in the fuse-board.
  2. In the charger plug, that goes into the cigarette lighter there is a fuse which may be blown. At the tip of the plug you'll see a ring. On most chargers it's silver but some are black. Unscrew the ring and the plug will come apart. Take care not to lose the small metal tip when you open it. Replace the fuse. If there's power going to the charger and this fuse is replaced your problem should be solved.
Posted on Dec 17, 2010
walesarumi
  • 6993 Answers
SOURCE: please help - my phone won't charge at all when i
The charging port of your phone should be the cause of the problem. It's either the charger is not contacting the charging port well enough or the charging port might be defective and needs to be replaced.
Use a pin to scratch the surface of the charging port and try again. If that doesn't work, then know for sure that you will have to replace the charging port.
If you feel you can do the replacement yourself let me know when you get a charging port replacement so that I can direct you.
Good luck.
Posted on Mar 21, 2011
Testimonial: "thanks for your help walesrumi that's exactly what the problem was. i took my mobile to a local repair shop who replaced the charging port in 15 mins"
lexzy80
  • 943 Answers
SOURCE: My Nokia E52 won't charge.
This problem can be traced to only a few causes. Listed below are the causes and possible solutions to this problem.
1. It is most likely that your battery may not be having proper contact with the terminal that does the main work for charging it. The three terminals that can be seen perform different tasks and as such, when that which is responsible for drawing power from the battery to operate the phone is in good contact, the phone might work normally but refuse to charge when that which is responsible for charging the battery is not properly in place. The easiest way to solve this problem is to turn off your phone and remove the battery. Try to clean the battery and all of the phone's terminals without using any liquid and then re-insert the battery.
2. Your phone may be having a faulty charging port and as a result cannot perform the complete task of charging the battery. In this case, the only thing that can be done is to try to dust the charging port and try to charge again. If this actually happens to be the exact problem, you might have to take the phone to a repairer so as to open up the phone and do a proper scan through on the phone.
3. lastly and most unlikely, the battery may have been damaged and needs replacement. This also depends on how long the battery has been in use. If it has been in use for more than 3 years, it is advised you replace the battery. Also, you can try connecting the phone to another power source to see if that helps too.
Hope this solution was helpful?
Posted on May 24, 2011
  • 123 Answers
SOURCE: My laptop won't turn on,
Good day. You can try to do these steps which is usually a normal solution to this kind of issue:
1. Take out the battery of your laptop
2. Remove main supply, or power cord
3. Hold power button down for 30 secs,
4. Put only power supply in or power cord
Note: do not put battery in yet
5. Turn laptop on
6. Put the battery in.
If this will not work you might consider contacting toshiba tech support for laptop for other resolution. Hope this information will be helpful in resolving your issue. Thanks for using fixya and have a great day.
Posted on Jun 25, 2011
Headphones Panasonic
if these are older headphones it's likely that the batteries have gone bad or are defective, if this is a new unit, (aside from returning it for working one) it could still be the batteries, but the other likely issue is the charging unit is defective. you could test with a volt meter to see if it's getting juice. you could also have a short in the headphones somewhere.
Dec 03, 2013 | Sennheiser RS 110 Consumer Headphones
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Removed drl relay now my dodge sx 2.0 won't charge
you need to replace the relay for this alternater to charge
Mar 04, 2013 | Dodge Neon Cars & Trucks
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
Motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
Sep 16, 2009 | Motorola Mobility S9 Headphones
Charging P168 with USB cord
i have heard someone say that the charger goes in both ways on your model, and that one way it charges and the other way it detects headphones. try flipping your charger upside down vice-versa.
Jan 29, 2009 | Dual Electronics CECT P168 Cellular Phone
Headphones change batteries
Any luck with that model number??
Apr 06, 2008 | Radio Communications
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
Radio Communications Logo
18 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
