Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Replace power cord
Cord is worn out
I have a kenmore vaccum i changed the power cord for the powermate and still not working the model # 11652512202 it work for a second then stop working
1) test the for loose connection in the power cord terminal tight or resolder
2) test the thermical fuse, for loose or defective
3) test for motor brush, repair, clean, and lubricate.
4) test for bel, loose, worn, or breake and replace.
God bless you
Sep 07, 2012 | Kenmore 28614 Canister Vacuum
Hoover U5465-900 Power Cord Replacement
hello,
Please checck out the following link for finding the manual of ur device!!...Im sure you can find a manual there!..
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Please post back for how things turned or for further assistance..Thank you!!...
Regards!!!...
Jul 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
The cord on my iron is worn at the swivel near the base and at the plug...can this be replaced since this is such an expensive iron...thanks for your help.
sure it can, first find the teg on the iron that shows the power rating. Then just go but a cord with compatable rating
Mar 10, 2011 | Vacuums
Using my unit (owned about 6 years - great service so far) it suddenly quit ... no wind down or 'prelude' like whine - growl - etc. -- it just quit running ... suggestions? clear filters?...
I agree with you having great service because mine only lasted two years. It sounds like the motor just worn out. If you don't smell any burnt electrical then replace the bushing for the motor. Good Luck
Jan 07, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
The mechanism that rolls back in the power cord seems to be working slower and sometimes not at all. Was wondering if the mechanism in question has an adjustment to increase the tension on it so the power...
it easy to adjust the roll back of vacuums the problem is hard to dismantle the unit to remove all the things to see the adjustment roll,all vacuums is need to remove all screw to open the unit even to replace the small parts like switch,and sometimes we cannot adjust the roll back if the spring is worn out we need to replace the new one,for me much better call and service technician for your comfortable and practically to not damage the other plastic part of the unit.and you get a warranty service for that one.
Jan 01, 2011 | Kenmore Vacuums
While vacuming my kirby turn off and on by itself
Hi there SmartAlec from NelsonVacuums.com.au here. The problem you are describing is usually (95% of the time) caused by a worn section of power cord. On a kirby you can easily replace the cord complete and its not to expensive. If you are in Australia the link to the 240V version is here. Hope this helps
Happy Vacuuming.
Jun 26, 2010 | Kirby G4 Bagged Upright Vacuum
How to replace Hoover PowerMAX power nozzle cord?
You can get the new cord at your local vac shop or you can take the power nozzle to the shop and have it repaired
Apr 27, 2017 | Hoover Powermax S3601 Bagged Canister...
Have no power to unit. have cleaned everything, but still no power
Please advise brand. Some vacuums have switches that become defective. I suggest using a VOM (Volt/Ohm/Meter) and follow the current into the vacuum. If it come to the switch, but not out of the switch - replace switch. Make sure cord is not frayed with a broken wire inside. Again the volt meter will ferret that out. If the motor has motor brushes one could be sticking or worn - replace.
If you are not comfortable working with electricity, please consult a reliable repair man
Mar 08, 2009 | Vacuums
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
