Question about Admiral Retail Supplies
Admiral washer water leak underneath
Water leak from flexible hose underneath the left front
jsrock516
  • 5911 Answers
SOURCE: washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
Posted on May 12, 2007
Washer_tech
  • 164 Answers
SOURCE: leaking water from underneath.
sounds like several problems. sounds like your boot stem/ seal is leaking and possibly the tub bearing is rusted. I generally replace both at the same time as long as the machine is apart anyway. As for the squealing and tub slamming to a stop, that is your brake package and bearing have dried and/or rusted and need to be replaced
Posted on Dec 26, 2007
SOURCE: WATER LEAKING FROM FRONT BOTTOM
Check your door boot, ours is doing the same thing. Found out there's a huge hole in the door boot seal.
Posted on May 29, 2008
SOURCE: Whirlpool Cabrio Leaks Water
you probably got coins or junk in the water pump on the bottom back of washer and it poked a hole in the housing. Thats what happened to me
Posted on Sep 16, 2008
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
Leaks left side underneath..only on rinse cycle
You can download the user manual at: http://lesepc.com/uploads/b/bosch-classixx-wfl-2066-manual.pdf
Apr 03, 2015 | Bosch Classixx WFL 2066 Front Load Washer
Front loader leaking underneath in the back corner on the left hand side
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
Aug 06, 2014 | Samsung Front Load Washer Control Board...
Old admiral clothes washer leaks at front
Troubleshooting Water Leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 25, 2009 | Maytag PAV2300 Top Load Washer
Water leak @ bottom front left with water turned off
this quite simple, inside the freezer compartment lower half there is a removable inspection cover, or what you may call the rear interior wall. remove this cover/wall and underneath the cooling coils is a drain hole for the defrosted water to escape to the pan located under the refrig. This hole is obviously blocked with some object, possibly just ice. As it is blocked the defrosted ice in the form of water cant exit the normal way so it is over flowing onto the freezer floor. everytime the defost element comes on more water will leak. solution is to clear the drain hose possible with hair dryer , or gently running a firm but flexible plastic tube through the drain tube to push any blockage on through. This has to be done very slowly and carefully.
May 19, 2009 | Jenn-Air JSD2789GEW Side by Side...
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Leaking water underneath washer
it could be the pump or the hoses its hard to tell til you get in there and look to see for sure.
Jan 14, 2009 | LG WM-2277HW Front Load Washer
Admiral washer bought yesterday
THERE IS A CLIP AT FRONT OF LID ABOUT 4 INCHES FROM BOTH SIDES THAT HOLDS FRONT ON. SLIDE BUTTER KNIFE BETWEEN CABNET AND TOP AT THIS PUSH IN TO RELEASE THE TWO CLIPS THIS SHOULD LET FRONT COME FOWARD AT THE TOP THEN LIFT UP TO REMOVE THIS WILL LET YOU SEE WHATS GOING ON. PROBLY A HOSE, BUT MAYBE SEAL AT CENTER ON BOTTOM OF TUB. IF SEAL TAKE MACHINE BACK. SEAL VERY COSTLY TO FIX. HOPE I WAS A HELP. FXIT
Dec 06, 2007 | Admiral AW22 Top Load Washer
Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
Nov 26, 2007 | LG WM-2277HW Front Load Washer
Retail Supplies Logo
69 people viewed this question
Top Admiral Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you an Admiral Retail Supply Expert? Answer questions, earn points and help others
