Question about Sharp MX-2700N Color Copier
MAINTENANCE CODE FX3
HOW TO CLEAR MAINTENANCE CODE FX3
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
Should be FK3 ,this is only fusing maintenance display no worry
Posted on Mar 21, 2014
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Need a charger for my panasonic-dmc fx3
Hi
Thanks for using FixYa. You can buy the charger from any of these links:
Panasonic-Dmc fx3 Charger
Panasonic-Dmc fx3 Charger-2
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Maintenance code TA does the printer go offline
Ok so the TA code means that the all maintenance counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 04
Then you can select what you want to clear so the maintenance count all
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
Jun 05, 2010 | Sharp MX-2700N Color Copier
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
Need to replace the lcd in lumix(panasonic) dmc-fx3
ebay seller rongyuanxie about 55.oo or do an ebay search with these key words... FX3 LCD DISPLAY SCREEN
hope this helps...
Oct 31, 2008 | Panasonic Lumix DMC-FX2 Digital Camera
Error code M1 appears and how to clear it . M2 is ok easy to clear.
How to clear an M1 code.
Solution:
To clear an M1 code, go to Counter/Maintenance/Maintenance Set and press the Clear key.
hope that help
Oct 21, 2008 | Office Equipment & Supplies
Strap on Panasonic DMC FX3
take the small loop and thread it through the strap hole, then pull the long loop through the small loop.
Oct 16, 2007 | Panasonic Lumix DMC-FX3 Digital Camera
Sharp MX-2700N Color Copier Logo
485 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
