Question about Maytag Dryers
Med 9600sqo Dryer does not heat
I have a TEDX640PQ1 it is taking 3-4 cycles to
If there is not enough air flow, it could take a long time. Or there could be one of the heating elements burned out. Oh, is it a gas dryer?
Oct 13, 2014 | Dryers
HOW DO I CHANGE HEATING ELEMENT ON MY ELECTROLUX DRYER?
You might try this step by step process. It is not for Electrolux, but the process should be similar. Changing the Heating Element
Apr 08, 2013 | Electrolux EIED55HMB Electric Front Load...
It's running fine but not heating at all on any
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101--==-
Aug 04, 2011 | Whirlpool Dryers
The dryer has does not always heat. You can turn the temp knob to different settings and it will sometimes heat up. It may work on the hottest setting one time then on the med or low setting another...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Hotpoint Dryers
My fisher paykel dryer is 3 1/2 year old. It works fine on med and low heat. On high heat, it heats up too much and turns itself off
clean the dryer of lint inside and also the vent tube:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Nov 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
The dryer is not heating up. I have cleaned the lent tray and have tried the different settings (whites, colors med,) and none of them are heating up. Could this be the coil or the heating element?
heatman101
Oct 14, 2010 | Frigidaire GLEQ2152ES Electric Dryer
LG DLG7188WM runs but no heat
I believe that it does. All of these parts should be functioning properly in order to dry the clothes well.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heat
Hi. thanks for the question. Was the venting checked .If not clean out the venting to the outside. This could be the cause
Sep 20, 2008 | Kenmore Elite HE4 Electric Dryer
LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
Feb 07, 2008 | LG DLE2532W Electric Dryer
Dryers Logo
10 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
