What is the density of dirt? - Office Equipment & Supplies
  • 457 Answers
The answer depends on the exact composition of the dirt. You can find an overview of the densities of selected materials at http://www.engineeringtoolbox.com/dirt-mud-densities-d_1727.html, ranging loose dirt at 76 lb/ft^3.
Searching other sources, there is a regular mentioning of NIST document 105-8, "NIST Handbook Specifications and Tolerances for Field Standard Weight Carts", and claims it names a "standardized dirt density" of 120 lb/ft^3. However, this is an urban legend; the referenced document contains no such definition.
Posted on Mar 20, 2014
Define the parts of desity
Density ' Define Density at Dictionary.com
www.dictionary.com/browse/density
  1. Cached
Density definition, the state or quality of being dense; compactness; closely set or ... is upon us, driven in large part by the returns to density, skills, and creativity.
Population density ' Define Population density at Dictionary.com
www.dictionary.com/browse/population-density
  1. Cached
Population density definition at Dictionary.com, a free online dictionary with pronunciation, synonyms and translation. Look it up now!
What is material density? - Definition from WhatIs.com
whatis.techtarget.com > Topics > Computer Science > IT standards and organizations
  1. Cached
  2. Similar
Material density, more often referred to simply as density, is a quantitative expression of the amount of mass contained per unit volume.
Jan 24, 2017 | The Computers & Internet
What is the weight of 68340 sq ft of dirt poured 18 inches thick assuming the density of the dirt is 105
Assuming you really mean a density of 1.05 as in your other question, about 3047 metric tons or about 3360 short tons.
Oct 14, 2016 | Office Equipment & Supplies
How many cubic yards of dirt are in 12 tons
This question can be solved only if you have a specific gravity (density - kg / cubic yard) of dirt.
Jun 04, 2015 | Office Equipment & Supplies
How to calculate density
density is defined as the ratio of the mass of a substance to the volume occupied by that substance.
To represent density one use the Greek letter RHO (looks like a rounded p)
RHO= mass/volume
Unit of density is gram/ cm^3 or kg/m^3
Relative density is the ratio of the density of a substance to the density of pure water (at about 4 degrees Celsius). In this relation both densities must be expressed in the same units.
Nov 17, 2013 | Office Equipment & Supplies
ERROR F5
error F5 02
Copy lamp lighting abnormality.
Sorry.... or Replace the copy lamp unit or Replace the MCU PWB
Valerio
May 17, 2011 | Sharp AR-5316 Advanced Digital Imager...
Panasonic FP 7718 error e3 40
E3-40 means there is a problem with the machine reading the black level density...this is not normally due to a faulty component but is normally due to to dirt inside the machine and possibly old/worn developer and /or drum in the machine. These are items that would have to be replaced by a service man.
Feb 03, 2011 | Panasonic Office Equipment & Supplies
Hi, I don't know if I should get single or double sided ram for this mother board, and is low density ram ok? Thanks, Wayne
This mainboard uses DDR400 memory
A High Density module is by far much slower than Low Density module at the same speed rating say PC3200/DDR400. High density modules are FAR CHEAPER, less than half the price when compare with low density modules and hence high density modules will NOT work on 90% of today's PC chipsets. LOW DENSITY modules have 100% compatibility with ALL systems and ALL chipsets. HIGH DENSITY modules only have 10% compatibility and are VERY SLOW.
So AVOID those 'High-Density - 128Mx4 config 1GB modules which is usually UNBRANDED and is NO NAME!
With this in mind it is far better to use low density Ram. Most RAM cards today are double sided, it all depends on the capacity of the RAM card.
Please rate this solloution as it it much appreciated.
Thanks.
Oct 31, 2010 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
How to clean Density Sensor of Hp 3500 ?
Thank you for this info. I used your advice to fix my HP printer and it worked. By the way, great link to HP support parges on the www.partshere.com site. I was able to fix my printer and by the way purchased more printer parts and fusers. Thank you again!
Feb 27, 2008 | HP Color LaserJet 3500 Printer
I need to reinstall my driver.
[International Portal Floppy Drive , www.ruanqu.net] is "TEAC low-density jumper floppy drive, SONY low-density jumper floppy drive, YE-DATA low-density jumper floppy drive, EPSON low-density jumper floppy drive, MITSUMI low-density jumper floppy drive, Panasonic low-density jumper floppy drive, Mitsubishi low-density jumper floppy drive, CITIZEN low-density jumper floppy drive, NEC low-density Jumper floppy drive "global distributor. ]
Nov 14, 2007 | Panasonic (r) Ultra-Compact Digital...
jasbo
jasbo
