Question about Whirlpool Ovens
Control board malfunction
Part # 4452890
    Guru:
  • 310 Answers
Control board 4452890 (equivalent to: 1057546, 4451856, 4451991, 4452898, 4453664, 8302967) is no-longer-available from Whirlpool. This board can be remanufactured at www.fixyourboard.com. The rebuild comes with a 2 yr warranty. Turn around time is a few days.
Posted on Aug 14, 2015
Oven door has stayed locked after self cleaning. Error code E1 F5. Can you advise
this is one of common issue with oven when control board starts malfunctioning. Try replacing your Oven Control board. if you know the Control board part number then I would recommend you to purchase one of them from Partsimple.com. Since Partsimple is more reliable, convenient, affordable for control boards. You can either purchase a new one or even a refurbished one which work same as new one..
Try once... and let me know if required any further help on this. TV parts Water Filter Washer parts Laptop Parts Replacement Parts...
Jun 27, 2015 | Whirlpool RBS305PDS Electric Single Oven
Tip
How to Repair Whirlpool E6 F2 Oven Code
Your Whirlpool Built-in Oven has failed and the electronic control is no-longer-available. You can have this control board rebuilt!
The common symptom is a display that intermittently goes blank, accompanied by an error code E6-F2. This is caused by a failure in the electronic control board (EOC).
The courteous technicians at www.fixyourboard.com in Austin Texas can rebuild this for you!
Control Board Part Numbers: 8302967, 4451856, 4451991, 4452890, 4452898, 4453664, 4453664.
Applicable Models: GBD277PDB6 GBD277PDB7 GBD277PDB8 GBD277PDQ6 GBD277PDQ7 GBD277PDQ8 GBD277PDS6 GBD277PDS7 GBD277PDS8 GBD277PDT6 GBD277PDT7 GBD277PDT8 GBD307PDB6 GBD307PDB7 GBD307PDB8 GBD307PDQ6 GBD307PDQ7 GBD307PDQ8 GBD307PDS6 GBD307PDS7 GBD307PDS8 GBD307PDT6 GBD307PDT7 GBD307PDT8 RBD245PDB11 RBD245PDB12 RBD245PDB13 RBD245PDQ11 RBD245PDQ12 RBD245PDQ13 RBD245PDS11 RBD245PDS12 RBD245PDS13 RBD245PDT11 RBD245PDT12 RBD245PDT13 RBD275PDB11 RBD275PDB12 RBD275PDB13 RBD275PDQ11 RBD275PDQ12 RBD275PDQ13 RBD275PDS11 RBD275PDS12 RBD275PDS13 RBD275PDT11 RBD275PDT12 RBD275PDT13 RBD276PDB11 RBD276PDB12 RBD276PDB13 RBD276PDQ11 RBD276PDQ12 RBD276PDQ13 RBD276PDS11 RBD276PDS12 RBD276PDS13 RBD276PDT11 RBD276PDT12 RBD276PDT13 RBD305PDB11 RBD305PDB12 RBD305PDB13 RBD305PDQ11 RBD305PDQ12 RBD305PDQ13 RBD305PDS11 RBD305PDS12 RBD305PDS13 RBD305PDT11 RBD305PDT12 RBD305PDT13 RBD306PDB11 RBD306PDB12 RBD306PDB13 RBD306PDQ11 RBD306PDQ12 RBD306PDQ13 RBD306PDS11 RBD306PDS12 RBD306PDS13 RBD306PDT11 RBD306PDT12 RBD306PDT13
on Aug 17, 2015 | Ovens
E2 f6
E2 F6 means that your oven temperature sensor has failed as well your electronic control board.
The oven temp sensor, electronic control board and the touchpad must be replaced.
Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Jun 01, 2011 | Whirlpool GBD307PD Electric Double Oven
What does the oven control pictures on the control mean , picture of fan understood,
what do the pictures mean on the dial indicator on a eurotec oven mean?
Dec 16, 2010 | Ovens
Whirlpool double oven rbd306pdb15 displaying code e6 f2. What does this mean?
HI. This code is in reference to the keys that initiate actions on your unit, The cancel key is malfunctioning at this time. Follow the procedure below to correct the issue.
1. Disassemble the control panel and check the keypad connector for firm connection (keypad connects to the control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate the keypad in to the control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Aug 23, 2010 | Whirlpool Ovens
I'm getting the codes E6 and F2 on my Whirlpool double oven. It won't turn on--help!
HI. This code is in reference to the control sector. There seems to be a malfunction that has been detected within the touch/key pad assembly. Use the procedure to isolate the damage.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jan 08, 2010 | Whirlpool RBD305PD Electric Double Oven
My Whirlpoolis showing F-1 Error of the LCD display? What can I do?
F1 code on your oven means "Electronic control malfunction". Clean contacts and reconnect all wires on the control board. If it does not help - replace oven control board. You'll also need to program the oven cavity size in the new control board. Model number is incomplete, so can't tell the part number, can be either 8301919 or 8301345
Oct 13, 2009 | Whirlpool RBS245PDS Electric Single Oven
I have a kenmoore oven model 91140465690 that keeps beeping and flashing the code F7 i need to know what part i need to replace for that code
HI, this F-7 code represents one or more function keys on the control board that are malfunctioning or stuck.
This will require the replacement of the entire control board(ERC,Clock).
Replacing the ERC(Electronic Range Control), will fix this issue. this control board will run you about $140.00 tops. you can order it on line by clicking the link i have provided below this text if you choose.
Click here to order you new replacement ERC.
Jun 17, 2009 | Kenmore Ovens
Flashed F5 when temp is heating up
HI, this code is signaling that your temperature sensor is malfunction. it will result in major damage to the control board and sensor wiring harness if it is not corrected soon. the will allow for high temps during the cleaning process that will ruin the ovens control circuit board.
replace the oven temp sensor soon.
May 19, 2009 | Kenmore 47834 / 47832 / 47839 Electric...
Ovens Logo
113 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
