Question about Sony Ericsson W200i Cellular Phone
Camera calirity camera calarity is no finegive me solution
    Genius:
  • 1,040 Answers
Your phone contains VGA camera which does not have superior quality but still can increase the quality(within some limit) go to settings and change the fallowing features
1) set resolution to the highest... (but in this case u will not able to use zoom feature) 2) set picture quality to fine
these are only two features available in your cell.
Posted on Apr 18, 2010
  • 51 Answers
Thought I'm a expert the same problem is being faced by me.Clean the lens regularly with the help of ear buds -thats the best of solutions I can give(since only it can fit other than dust)
Posted on Feb 17, 2010
Had-over-13-million-when-you-shut-the-game-down-for-up-grade-and-when-it-came-up-had-658-thousand
can i have calarence, to go back in and play, a lot of my money went to my brother, he is a reckless player. i felt sorry for him. i told him i would never help him again.
Nov 08, 2012 | Evermoremedia DoubleDown Casino
Por Que no hay corriente en el cable Que va de la bobina al distribuidor
la computadora controla todo si cuando abres el swicht prende la bomba de gas por 3 segundos cuando la maquina da vueltas el distribuidor tambien dentro del distribuidor tiene un sensor que manda la senal a la bobina dando el tiempo de encendido ..... pero puedes calar primero con otra bobina . suerte
Dec 16, 2010 | 1992 Honda Accord
MAXX 122b BAD CHARGING
MAXX 122b BAD SOUND CALARITY
Oct 23, 2010 | Garden
Took stop motion knob off how do the pieces go
You should have a three pronged washer, put that on first anyway round, then put the stop motion wheel on and tighten fineger tight, tighten the small screw that should be on the stop motion wheel and tighten a bit more, if it does not tighten up take the stop motion wheel off and put the three pronged washer in a different position.
Jul 17, 2010 | Sewing Machines
Caliberation
Normally it is a matter of a few seconds, doing the calibration clicking a round or two - but if the phone is faulty it is not possible to calibrate, and the process will go on for ever. In that case try to get the phone replaced by the seller (if you just bought it)
Apr 27, 2010 | Dual Electronics CECT P168 Cellular Phone
Pictures look like they are in 3D
it sounds like your convergence is off.
you have Red, Greed & Blue projection guns
through your menu's you will find adjustments for them ...
set your green first then align then red and then blue to the green..
when making this adjustment the tv should put up a caliration signal called a crosshatch
a matrix of H and V lines to align
Apr 15, 2009 | RCA HD52W56 52" Rear Projection HDTV
Can not showing images calirity
You can try to change the resolution settings in control panel>apperance and personalization> adjust screen resolution(VISTA) or control panel>display(or personalization)settings. Try setting the slider as far to the right for the resolution that you can, the screen will flicker and give you the option to keep the settings or change back and a count down timer, if you do nothing (I.E. the screen is completely black) it will automatically (after about 15-30sec) go back to the previous setting.
After you find a setting that seems to work, check the advanced settings, in the refresh rate it should be the highest possible setting (I.E. 60hz) this will stop or prevent any screen flickering. I hope this helps.
Feb 12, 2009 | IBM ThinkPad R50e Notebook
Fusion sub..
check the impedenc on amp and speakers.if speakers have lower ohm the amp cant push them also can cause damage to amp.how do you have everything wired must be specific.high level inputs,rca,.how is the radio and amp wired together,where are you getting power sup[ply from and how?
chriszambrotta@yahoo.com
Jan 09, 2008 | Fusion FEW12PK Car Subwoofer
Camera calarity is not good
Hi have you tried changing the setting on the camera like picture quality also make sure the lense is clean and free frim dust.
Often you get dust underneath the case between the lense and the case but if you are unsure about taking the case off then dont do it as it is difficult to get off and back on let me know how you get on ok
Dec 10, 2007 | Nokia N73 Cellular Phone
Sony Ericsson W200i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
