Question about Crafts & Hobbies
Mattybpic pick
We are not able to pick up incoming calls the phone message states "make calls first"???
It might be that your pick up key is mislabeled/programmed. Press feature * 0 then the pick up key to identify what the feature is on the button. If it's not pick up, exit out of button inquiry press feature * 3 the button you want to program (pick up) then press feature 75 That will program it as a group pick up key
Apr 28, 2014 | Nortel Meridian M7208 Corded Phone
5 students out of 20 get and A. 3 students of the 20 are picked at random. what is the formula to find out the chances of all 3 picked students getting and A?
The chance of the first pick having gotten an A is 5 out of 20. The chance of the second pick having gotten an A, assuming the first pick also got an A, is 4 out of 19. The chance of the third pick having gotten an A, assuming the first two also got As, is 3 out of 18. Multiply the three together to get the chances of all three picks having gotten As.
Aug 01, 2013 | Computers & Internet
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Oct 30, 2012 | HP Office Equipment & Supplies
How do you replace the feed roller on a fujitsu 4097 scanner
Hi Ranji,
Thank you for contacting Fixya.
The life span of the Pick roller is about 200,000 sheets or one year. Use Abrasion counter on the operator panel to estimate when the Pick rollers need replacement. The life span may be decreased by as much as half when carbonless sheets are frequently read. To replace Pick Rollers, please follow the steps provided below:
a. Remove Guide AASY. b. To remove the Pick rollers, turn the stopper counterclockwise. c. To remove the Pick roller 1, move the Pick roller 1 toward the left then lift it. d. Right after removing the Pick roller 1, remove the Pick roller 2 with the same way. e. To attach the new Pick rollers, place the Pick roller 1 from right above the groove for the Pick roller 1. Put the shaft of the Pick roller 1 into the groove. Then, slide the Pick roller 1 toward the right side. A Pick roller 1 has the groove in its rubber. Make sure that the bushing is securely fixed to the grooves. f. Attach the Pick roller 2, then slide the Pick roller 2 to the right. Make sure that the bushing is securely fixed to the grooves. g. Turn the stopper clockwise to secure the Pick rollers.
Hope the above information is helpful.
regards,
TechSatya
May 20, 2010 | Fujitsu M4099D/FI-4990C Scanners
Nedd to test coil on an 89 chevy 2500, dont know parameters
PICK-UP COIL (HEI)
1. Isolate 2 pick-up coil lead wires. Remove pick-up coil connector from module. Connect ohmmeter to either terminal and ground. See Fig. 4 . Connect pump and apply vacuum to test vacuum advance unit. Replace vacuum advance unit if inoperative. Connect ohmmeter to pickup coil terminals. Operate vacuum pump and observe ohmmeter throughout the vacuum range.
2. Attach ohmmeter to one pick-up coil terminal and distributor housing. Set ohmmeter to middle scale. Operate vacuum advance throughout vacuum range. Reading should be infinite at all times. If not, replace pick-up coil. See Meter "A" in Fig. 4 .
3. Connect ohmmeter leads to pick-up coil connector terminals. Operate vacuum pump to ensure proper operation throughout vacuum range. Flex terminal wires by hand to check for possible intermittent defects in wiring or connectors. Pick-up resistance should be 500-1500 ohms. If resistance is incorrect, replace pick-up coil. See Meter "B" in Fig. 4 .
NOTE: Activation of the vacuum advance may align trigger wheel tooth and pick-up coil pole piece causing ohmmeter pointer to deflect. This
deflection should not be diagnosed as a faulty pick-up coil.
Jan 20, 2010 | 1990 Chevrolet K2500
The printer will not pick the paper from the lower tray. It tries to pick the paper from the upper tray even though it is set to auto pick the source but will not pick from the lower tray.
Hello, just clear paper pick up roller.
Open front cover, remove toner cartridge and you will find paper pick up...use wet cloth or alcohol to clear it... Good luck!
Oct 29, 2009 | HP LaserJet 1020 Printer
Minolta copier di-450 code : c-143e
The correct error code is C 143E - EDH malfunctions.Please reset the malfunctuion code to open and closed the front door,or turn OFF wait 5 sec. and turn ON the power switch.If the problem persist change the image processing board.
Pick up motor malfunction
Whwn the document handling tray goes to up the pick up raised position sensor is not unblocked when the motor started turning forward.Whwn thw DHT goes down the pick up lower position sensor is not unblocked after the motors started turning backward.
During ascent motion check :
1.Foreign matter on pick up motor gear
2.Pick up motor operatio.The voltage across PJ11A 1 of main control board and GND is 0V when the motor is deenergized and 24 V when the motor is energized when the DHT is raised after the malfunction reset.
3.Pick up raised position sensor operation.
Change the motor,sensor or main control board.
During descent motion
1.Check the pick up motor gear.
2.Check the pick up motor operation
3Check the pick up lower position sensor operation.
Aug 28, 2009 | Minolta Office Equipment & Supplies
Washburn guitar mg-20 pick up switch position 5 neck pick up no sound or noise humm or anything. all other positions and configurations work?
if everything is standard on that guitar then the only reason that pick up wouldnt work is because its a defective pick up or a wire is disconnected. it may also be possible that the selector switch is bad. take a small screw driver and tap the pick-ups in all positions while plugged in to the guitar amp and the volumes up ( not all the way) just loud enough that you can hear the tapping. you find the bad pick up when you cant hear the tapping with that pick up selected.
Feb 22, 2009 | Washburn Music
HOW TO CHANGE THE AUTO LINE SELECTION WHEN PICKING UP HANDSET
Sounds like you have two seperate line groups programmed in the system, Program 32 " Automatic Preference " controls the lines the phone will automatically be connected to when the telephone handset is taken off hook or the Spkr button is used.
Apr 24, 2008 | Toshiba DKT-2010 Corded Phone
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
Crafts & Hobbies Logo
27 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
