Question about LG LMVM2085ST Stainless Steel 1100 Watts Microwave Oven
Fan will not turn off
Exhast fan will not turn off
The GE Spacemaker Microwave Oven model JVM1540 makes a loud fan noise whenyou turn it on. Sounds like the exhast fan but it not?
It sounds like from the description when it is running the noise comes from the magnetron, some microwaves are louder than others, but this could be an early sign the magnetron is going.
Mar 13, 2012 | Microwave Ovens
NN-SD297S The exhast fan still works but the oven
Due to the technology used in this model, there are no user serviceable parts inside. Call a Panasonic appliance engineer.
Mar 07, 2011 | Panasonic NNSD297SR 1200 Watts Microwave...
Spacemaker XL JVM1340WW002 Exhast Fan does not turn off (ever). Light not effected, Door open/closed makes no difference.
Hi, you have a faulty control board as a result of a stuck relay on it which makes the fan to run continuously. The solution is to replace the control board....
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 01, 2011 | Samsung Microwave Ovens
Exhast fan and light not working. Can hear relay trip when button pressed. Microwave/convection oven functions work ok.
This may just be a blown bulb if the fan and light are in series.
If the bulb and fan connections check out ok, it may be a fault in the power supply to that side of things.
Do not operate with covers off or override interlocks to test. Test only with unit unplugged.
Aug 28, 2009 | Microwave Ovens
Exhast fan seems jammed. When you try and run it you get a bad loud hummm like the motor is jammed. The fan had been noisy when running before, so wondering if it was loose before this.
Noisy can indicate a bearing failing and it sounds like it finally siezed. Try spinning the fan by hand and run it again. It might need the bearings lubricated to get a little more life out of it.
Eric
Jun 25, 2009 | Whirlpool GH7145XF Microwave Oven
My exhaust fan will not cut off my microwave
Since this was not replied to, I will called it closed.
Please do not rate this unless you still need a solution and will reply back first with the information I requested.
Jan 17, 2008 | Maytag MMV5186A Microwave Oven
Noisy Exhaust Fan
check exhast fan fittings and clean the bush..
Nov 29, 2007 | Frigidaire PLMV169DC Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
LG LMVM2085ST Stainless Steel 1100 Watts Microwave Oven Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
