Question about Estate TAWX700JQ Top Load Washer
Water leaking from cabinet top
Water leaks from cabinet top
I have a GE Top Poad WasherWJRE5550H1WW that intermittantly leaks
There seems to be an overflow drain from the top of the tub to the bottom (inside the cabinet). I don't know why this was designed to dump water onto your floor.
May 13, 2010 | GE Washing Machines
My washer is leaking water near the water tube located right in front of the washer. Do I need to replace something or can I seal it?
most likely u will need to replace part.u should remove the cabinet to get a better look at where the leak is . the cabinet comes off from the front.
Oct 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
MOdel 110.92579110 leaking water out bottom of
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92579110
LEAKING:
See the Sears site sub-components for the agitator, basket and tub. It's possible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The illustrations also show how to remove the transmission.
OIL
The black oil / fluid that you see is likely coming from the transmission.
Since it seems to be "spraying" around the inside of the cabinet, I'd assume that it is leaking from the top seal between the transmission and clutch.
See the following for a parts breakdown of Whirlpool top load direct drive washers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you look at page 15, you'll see a Seal, Gearcase Cover. It is possible that that is the cause of your transmission leak.
The rust on the bottom of the transmission may (hopefully) be simply caused by the water leak.
I'd remove the gearcase cover (8 bolts) in order to check the gearcase cover seal, and to check the oil level. The Whirlpool transmission takes about 15oz or 80-90 weight oil.
Oct 17, 2009 | Kenmore Washing Machines
Water leaks in front not all the time all hoses are tight took apart never leak put back together and it leaks
If you can remove the cabinet top and still get it to run, look for overfilling of the outer tub and possibly seeing where the leak is coming from. You may have a seeping water valve the keeps raising the water level as it runs.
Sep 23, 2009 | Roper RAS8445KQ Top Load Washer
Water leak upon filling at top/cabinet joint
Raise the washer top and inspect the water fill tube and the water level air hose.
You will need to set the timer to fill while you are watching for the water leak.
Feb 23, 2009 | Maytag SAV2555A Top Load Washer
Leaks water
Probably a bad water pump. That is were the Kenmore usually leaks.
2 screws on the top panel right and left sides.
Remove these screws, tilt the control head backwards.
Remove the wiring harhess connector.
Remove 2 clips holding the cabinet to the back panel.
Remove the cabinet by pulling forward.
Pump is attached to front of motor.
Feb 21, 2009 | Kenmore 24642 Top Load Washer
Water leak
remove the 2 screws holding the console in, they may have trim on them.flip it up and you will see 2 metal brackets on left and right. pop thos off taking note how they are on there, disconnect connector on the top of the cabinet(door switch wires)lean cabinet foward pull towards you.it is know free of the rest of the machine. put back reverse of these directions making sure the back lines up properly with the cabinet.
Oct 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaks water from the bottom
Your pump is probably leaking. It's mounted right at the front of the cabinet to the motor. It's held on by 2 clips and 2 clamps, very easy job. Part number for the pump is 3363394.
Oct 08, 2006 | Whirlpool Ultimate Care II GSW9650LW Top...
Estate TAWX700JQ Top Load Washer Logo
19 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
