Question about Sharp INK ROLLER - BLACK FOR EL-2192C EL-2192 GII EL-2192P EL-1801C
How do you load the paper into the calculator?
How do i load my printer paper ti-5045sv
To load paper into a ti-5054 sv calculator.
  • Turn Calculator on.
  • Press down on the front edge and slide in the direction of the arrow.
  • Insert paper on the roller so that the paper rolls out toward the bottom, and the loose end is closest to the calculator.
  • Cut of the end of the paper.
  • Insert the end of the paper into the printer slot in the back of the calculator.
  • Press the paper feed button ( karmahm_0.png) until the paper is in position.
Mar 17, 2011 | Texas Instruments TI-5045 SVC Calculator
Need to load paper into calculator
There is a small flat area on the back of the calculator. Put the paper in this hole and press the FEED button.
May 06, 2010 | Canon P170-DH Calculator
Can't load paper in a TI-5032 SVC
I found the manual that explained how to load the paper. I do not need any future assistance. Delete my request for help! Thanks -
Nov 30, 2009 | Texas Instruments TI-5032 SVC Calculator
I can't get the paper started to load into my machine
Load paper on paper arm.
Cut edge of paper at a diagonal.
Feed paper through the **** at the back of the calculator - you have to look carefully to see it.
Press the Feed button to advance paper into calculator.
I had a tough time - finally dug up my manual. Hope this helps.
Nov 07, 2009 | Canon P23-DHV Calculator
How do I load paper in my canon p23 dh v printing calculater
Put paper roll on paper arm with the end of the paper coming down from behind. Cut paper on a diagonal. Insert the paper into the **** at the back of the calculator. You need to really look to see it. Use the feed button to feed the paper through..
Nov 06, 2009 | Canon P23-DHV Calculator
Load paper into cannon p23-dh v
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
Dec 30, 2008 | Office Equipment & Supplies
HOW TO LOAD THERMAL PAPER IN DR-T120 CALCULATOR
Simply place the paper between the plastic posts. Put top portion down; feed paper up slightly - put smaller front plate back in place and press feed button.
Dec 02, 2008 | Casio DR-T120 Calculator
How do you load paper into the printing calculator?
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
Oct 10, 2008 | Canon P23-DHV Calculator
Loading paper
Follow the illustrated instructions on the first page of this manual.
Jul 18, 2008 | Sharp EL-1197PIII Calculator
Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Jun 20, 2008 | Canon P23-DHV Calculator
Sharp INK ROLLER - BLACK FOR EL-2192C EL-2192 GII EL-2192P EL-1801C Logo
16 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
