Question about Vehicle Parts & Accessories
Need a new headlight
Need to replace headlight
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Ok go get one and put it in
Posted on Sep 09, 2014
Headlight for 2004 trail blazer
If it's just a bulb replacement open the hood and with one hand push in on the headlight, with the other hand inside, pull up on the white plastic retaining clip. This will release the bulb. Pull it out forward, then replace with new bulb (be careful not to touch the new bulb, oil from the hands can cause bulb to burst.)
If you need to replace the whole headlight assembly I would try buying used for a better price.
Sep 16, 2013 | 2005 Pontiac Aztek
How do you change the headlight
On a Newer Vehicle you'll replace the Headlight Bulb
Open the engine compartment hood.
Locate the back of the headlight to determine the lamp and bulb type.
Decide which bulb you need to replace.
Purchase the correct bulb for your headlamp.
Behind the headlight the lamp the socket is removable.
Remove Socket then replace lamp (bulb).
Carefully re-install the socket
On Older vehicles:
Remove the screws that connect the headlamp frame to the
bracket holding the headlamp. Make certain you turn only
the screws that hold the lamp frame, not the adjusting screws.
Disconnect the electrical connector in the back of the lamp
by pulling the socket away from the headlamp with your hand.
Remove the headlight from the bracelet area and discard it.
Replace with the new headlight, making sure that it is positioned
right side up.
Plug the wire socket into the new headlight, which holding the
headlight securely.
Replace the headlight into the frame.
Place the frame onto the headlight bracket.
Reattach the screws to hold the frame and bracket in place.
Do not adjust the setting screws for the direction the headlight
shines.
At night partk in front of a wall and shine your lights on the wall
so see if the headlight shifted during installation.
Jul 14, 2012 | Cars & Trucks
I have a 2002 x-type jaguar,i need to replace the front lights that are burn out.do i need to take the hole front bumper off? how?
Inspect/Replace-I don't think that removing the bumper is necessary. There can be slight variations in procedure from one model to another when replacing headlights. For instance, on some models the turn signal light assembly must be removed before the headlight can be replaced. Overall, however, the procedure does not differ much from the following typical instructions.
Make sure the replacement bulb is the same type and part number as the one that is being replaced.
f19-22.jpg Comparing the old and ther replacement headlamps. To Replace:
  • Remove the headlight bezel retaining screws. Remove the bezel. If necessary, disconnect the turn signal lamp wires.
  • Remove the retaining ring screws from one or both lights.
  • Remove the retaining rings.
  • Remove the light from the housing. Disconnect the wiring connector from the back of the light.
  • Push the wiring connector onto the prongs at the rear of the new light.
  • Place the new light in the headlight housing. Position it so the embossed number in the light lens is on the top.
  • Place the retaining ring over the light and install the retaining ring screws. Tighten them slightly.
  • Check the aim of the headlight and adjust it, if necessary.
  • Install the headlight bezel. Secure it with the retaining screws.
  • Connect the turn signal lamp wiring (if it was disconnected).
Oct 31, 2010 | 2002 Jaguar X-Type
How do you replace the headlight on a 97 lexus es300. Thank you
Obviously the furst thing you need to make sure you have are the replacement lights
Step 1 Open the hood and unplug the HID power connector from the back of the headlight assembly
Step 2 Pull the protective rubber boot off the headlight housing.
Step 3 Squeeze the tabs on the wire clip that holds the headlight in place.
Step 4 Pull the headlight out of the back of the headlight housing assembly.
Step 5 Insert a new headlight.
Step 6 Secure the headlight with the factory wire clip.
Step 7 Replace the rubber boot.
Step 8 Plug the HID electrical connector back into the headlight.
Mar 29, 2010 | 1997 Lexus ES 300
96 camry headlight dont work
Headlights are one of the most important safety features on your car, but they can only do their job if they're properly maintained. It's not just burned out headlights that cause problems; headlights that are dim or incorrectly aligned can also lead to accidents. Fortunately, learning how to repair headlights is something even the least mechanically inclined person can do. When you know how to repair headlights yourself, you can save up to several hundred dollars on mechanic's fees. Here are some tips on how to repair headlights with common problems.
Headlights that don't turn on
If you're headlights aren't working at all, the most likely cause is a burned out bulb. All you need to do to repair the headlights is replace the bulb. If you have plastic lenses, you can take out the old bulb by removing the lens and unscrewing the bulb from the back of the lens. With glass headlights, though, you'll need to replace the whole glass. Since you're buying new bulbs anyway, consider picking up one of the new, brighter types of bulbs, such as the halogen or xenon types.
When you've got your replacement bulb, install it and turn on the lights. If the headlights still don't work, it's a sign of an electrical problem. Because electrical problems are relatively complicated to repair, take your car to a mechanic before you try to do anything else with the headlights.
This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | 1996 Toyota Camry
I need to change the low beam headlight bulb
  1. Remove headlight mounting bolts and nut
  2. Remove assembly
  3. Install headlight assembly (with new bulb)
  4. Replace/tighten headlight mounting bolts and nut
Oct 30, 2009 | Hyundai Motor 2003 Elantra
Need to replace headlight bulb in honda civic 2003
How To Install Replace Headlight and Bulb Honda Civic Sedan 01-03 1AAuto.com
Dec 31, 2008 | 2003 Honda Civic
Headlight replacement instructions
Release the hood latch inside the Rodeo. Raise the hood and look down behind the headlights. The old bulb and assembly are held into the headlight from the back side of the the headlight. There is not a great deal of room to work behind the headlight because of the battery on the passenger's side and the air cleaner box on the driver's side.
Grip the large round plastic nut with your hands and give it a quarter turn counter-clockwise. Carefully remove the head light and plastic nut. Look for the release lever to depress and pull on the old bulb at the same time. It will unplug very much like your computer power cord. Be careful not to drop the plastic nut.
Now plug in the new bulb and replace the plastic nut. Carefully insert the bulb into the headlight and give the plastic nut a clockwise quarter turn and try the new light.
I just replaced both of my headlights last night and I am an accountant.
Oct 20, 2008 | 1999 Isuzu Rodeo
Vehicle Parts & Accessories Logo
18 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
