Question about Frigidaire DGBD2432K Dishwasher
What does pf mean when it comes up on my dishwasher model no. fdb2320rec2
Why does p f come up on my dishwasher
  • 14 Answers
POWER FAILURE.. you lost power to the dishwasher either whole house or just dishwasher,,,not sure why we need the dishwasher to tell us that we lost power, but too many can cook the control board,,,did mine. good luck
Posted on Mar 22, 2014
What does fridgidaire dishwasher error code pf mean
Usually the PF code means a power failure. You should check the wiring to the machine for loose wire nuts or wires with missing insulation touching each other or the side of the wiring housing. (You'll need to remove the access panel at the bottom of the dishwasher to check the wiring.)
If the wiring is fine, check the switches in the door latch. The white wires should test fine for continuity. If those switches are fine, then the control board has a wiring fault. Replace the appropriate parts. If your dishwasher is under warranty, contact Frigidaire.
If you add a comment with the model of your dishwasher, I may be able to help you find the replacement parts.
I hope this helps.
Sep 21, 2014 | Dishwashers
My electrolux dishwasher is showing a PF error and it will not work?
Code PF means power failure turn off the breaker that handles the dishwasher for a few mins. then turn it back on. it should reset itself
Jun 05, 2014 | Dishwashers
My Frigidaire electrolux dishwasher model # FDB2310LCC0 trips a pf code 40minutes into the cycle and it is not the circuit breaker. how do i correct this problem?
Good Morning Doria, thank you for allowing me to assist you!
Typically PF means power failure and you should be able to start a cycle. Unplug the unit or flip the household circuit breaker. Wait about ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it.
Best of luck!
Oct 07, 2013 | Electrolux Frigidaire Professional Series...
The initials "pf" come on and prevent our fridgidaire dishwasher from continuing it's cycle. What is the problem?
"PF" generally means Power Failure. First, be sure that the door is latched tightly. Vibration may loosen the latch causing the unit to stop. Also check your circuit breaker. Flip it to the "tripped" position and firmly back to the "on" position.
If this model is an "electronic" unit (for example uses a touch pad for programming), there may be a loose connection somewhere in the wiring prior to or at the junction box under the dishwasher. The electric "noise" generated there might confuse the dishwasher's computer. Best to have an electrician look at this.
Aug 10, 2010 | Frigidaire FGHD2471K Builtin Dishwasher
My frigidaire dishwasher is blinking lights and a
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Jun 24, 2010 | Frigidaire Professional Series 24 in....
Kenmore ultra quits working pf and e8 light come on
If your pf light comes on that means that your outdoors fuse needs to be replaced. The same thing happened to me and I bought another dishwasher for the same proble to occur. I don't know if it's to late but the only thing wrong is your fuse is blown. Good luck!!!!!
Nov 23, 2008 | Kenmore 13599 / 13594 / 13592 Built-in...
Frigidaire Dishwasher
PF is merely an indcator to you that you've experienced a "power failure" normal to appear every timr you lose power and/or reset breaker. pressing any one of the buttons will clear it.
Mar 15, 2008 | Dishwashers
Frigidaire DGBD2432K Dishwasher Logo
70 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
