Question about Ariens 926054 Snow Blower 2 Stage 32 In
Restarting problem I was blowing snow and I let go of the safety lock handle and now I can't get it started. What do I do to fix it?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Check the switch that the Lock operates.
Posted on Nov 25, 2014
ISnowblower is throwing snow, but also putting snow up on the machine ananda on me. When I finished one row the machine is covered with snow!
There are many factors that can cause this to occur. ONE IS THE WIND, LIGHT SNOW WILL BLOW BACK OR SNEAK THROUGH HE CRACKS OF THE EXIT. if THE SNOW ON THE OTHER HAND IS WET THEN THE EXIT CHUTE WILL ALLOW THE SNOW TO DROP ON THE MACHINE. ONE WAY TO FIX THIS REQUIRES THE ADDITION OF RUBBER STRAPS, YOU WILL NEED TO DRILL HOLES IN THE IMPELLERS and attach the rubber, (this can be cut from an old tire or a floor mat or other rubber that is around 1/4" thick or more. Make the parts the width of the blades and around 2-3 " from tip to base. This will stop the snow from collecting on the walls of the blower and throw the snow farther from the blower.
sorry about the uppercase, did not know I had hit the caps lock, not a touch type person.
Neal
Feb 26, 2015 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Not getting spark troy bilt snow blower model 7524
1st disconnect the auger /drive safety kill switch wire , see if it starts ? no? then it's most likely a bad ign modual or ign coil yes? then look at auger/drive control handle , i bet the spring broke and its not moving all the way up to disengauge the auger or drive
reconnect safety wire before using machine
Feb 23, 2015 | Garden
932 ariens shuts engine down as clutch is engaged to throw snow
Your problem would be in a safety shutdown switch.
some Ariens blowers have a two handed safety switch whitch is located on back of blower right lower side (inside of body)
You have to remove 4 transmission pan bolts to see it.
The other location is under the metal face plate between the handle bars.
Some of them have a third handel on right side of handle bars that has to be depressed to run auger .
Mar 01, 2014 | Ariens Garden
My snow blower shuts off when engaging in snow
the rpms are not high enough adjust the carb or cable
Jan 06, 2014 | Garden
Tecuseth Snow King Engine. Starts fine. When I engage snow blower engine dies.
couple of things come to mind. Safety switch. Engine not running at full speed or snow thrower is locked smooth up
Dec 17, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
Ariens st350 snow blower wont blow snow, augers wont spin
there is a bolt that goes thru auger and spinning shaft (look for a hole where it once was) holds the augers to the spinning shafts, it is called a shear pin, it is a safety feature, and made of softer metal, so if you pick up something too hard with the auger, it wont lock up the engine, or break engine crank shaft.find an ariens repair shop to purchase the shear pin so you get the right softness of metal.
Mar 05, 2013 | Garden
Snowblower doesn't throw the snow very far, and every time I stop it, it takes a while for the auger to start turning fast enough to blow the snow. Feels like the torque isn't there. This is a Husqvarna...
The most common cause of this is the drive belt is worn.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission.
With the engine not running, have someone depress the drive lever and check the blower belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
You can get parts for you Craftsman and most Husqvarana, MTD made models through searspartsdirect.com. You can also get parts through jackssmallengines.com or your local dealer.
If you are unfamiliar with repairing machines take it to your local dealer. They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions to troubleshoot this problem farther. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Garden
My Troy-bilt Storm 7524 snow blower goes off after 10min running
it sounds like it may be you armeture[coil], it heats up and stops.
Dec 11, 2009 | Garden
Ariens 926054 Snow Blower 2 Stage 32 In Logo
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
