Question about GE Refrigerator Temperature Control Wr9x521
How do I install the WR9X521
Odd that the part shipped is different than what is installed originally.
My screen cracked across the middle, how much does it cost to fix the screen?
I recently cracked the screen on my mac. The store wanted 1200 to fix it. If the computer is usable ignore it. If it isn't buy a new computer. Broken screens are very expensive to fix...sorry mate ; c
May 04, 2011 | PANDIGITAL Digital Book 843967071153...
Tip
Access software setup shipped with HP PC after Retail OS Installation
Scenario: You have installed a Retail Operating System but have left the recovery partition (usually D drive) on your HP Desktop PC and you want to access the original softwares shipped with the PC.
Tip:
1. Click start, run. Clear contents of run box.
2. In run box, type "D:\hp\apps" without quotes and hit ok.
3. This will open a folder that would show couple of folders. These are the applications shipped with your PC. You can identify the software you need. In that folder, open SRC folder. You will find setup for the application here. Install the application from here.
on Jan 18, 2010 | Computers & Internet
My sony vaio laptop was from japan. model VPCEB37FJ. I want to change the language from japaneese to english
The original language of the operating system cannot be changed without also updating the associated driver files, and those driver files are not available in languages other than the one that ships on the computer. However, the operating system can be configured to display in a different language by upgrading to the Ultimate version of the Vista operating system and then installing and using the appropriate Windows Vista language pack.
To change the language settings, a language pack must first be installed. Follow this procedure to download and install a language pack.
  1. Click the Start button, and then click Control Panel .
  2. In the Control Panel window, click Clock, Language, and Region .
  3. In the Clock, Language, and Region window, under Region and Language , click Install or uninstall display languages .
  4. Under Choose to install or uninstall display languages , choose Install display languages .
  5. Under Choose your method of install , choose Launch Windows Update
  6. Under Select the updates you want to install , select the Language Packs to install and click the OK button.
    NOTE: The Language Pack updates will be listed under the optional updates .
Apr 10, 2011 | Sony VAIO VGN-FJ270/B Notebook
I formatted my pc purposely to install windows 7.after this,windows fail to install so i re-install windows xp.after this my wireless fail to work.when i tried it says'no supported wireless adapters...
If your computer originally was shipped with Windows XP pre-installed, and you used the "System Restore" CD/DVD disks that were shipped with the computer to reload Windows XP, the correct device-driver for the wireless-adapter should have been automatically installed.
If you used a different disk to reinstall Windows XP, then you can try two things:
1. Access ACER's web-site, do a search for your model, and see if the web-site offers the device-drivers for Windows XP for your model, or,
2. use an Ethernet cable to connect your computer to the Internet, and access: http://WindowsUpdate.Microsoft.com and do a "Custom" scan. When the scan completes, click the "Optional Hardware Updates" section, to see if Windows Update is offering a device-driver for your wireless adapter. If so, select and install that adapter.
Mar 17, 2011 | Acer Computers & Internet
Install win xp on hp pavilion dv6700
What sort of information are you seeking?
Any 'computer-store' will take your tower, and the original HP "System Restore" set of CD-ROMs, and will, for about $50 to $75, re-install the original Operating System that was shipped with the computer.
If you have lost those CDs, they can help you order a replacement set of CD-ROMs directly from HP, basically just for the cost of courier-shipping from HP's warehouse.
Apr 10, 2010 | Microsoft Windows XP Professional SP3 Full...
Corrupted operating system dell xps m140. how to
Dell ships their system with factory installed software and recovery discs.if you formatted using a different , the pre installed recovery are gone. so CALL DELL customer service and have them ship you out a recovery disc its for free, i guess if your still under warranty.
Oct 30, 2009 | Dell XPS M140 Notebook
Windows can't install because it says it can't find a hard drive. Setup indicated both HD's are there and working. Installing Windows 2000 from Disc. Changed boot sequence so Rom boots first. Windows loads...
Check for sata drivers, if it is system is shipped with SATA hdd, need to install SATA Raid drivers during reinstallation .I believe that the dell system was originally shipped with Windows XP or Vista Operating system which has SATA drivers for SATA hdd. Since windows 2000 Operating system does not have SATA drivers hence unable to recognised hdd.
Aug 17, 2009 | Dell Dimension 9100 PC Desktop
Where to get shipping bolts for wssh300g1ww
Hi Judy
Your best bet would be calling GE and see if there is a part number for those bolts and where you can get those.. Installer usually throw those away after installation..
Here is their tel #1 800 626 2000
Jun 29, 2017 | GE Washing Machines
Have lost most of digital channels
I had similar problerm.
Solution was to go to Functions - to Others - to SETUP - select Shipping Conditions.
After the unit has been reset to shipping conditions, switch off.
When next switched on it will autosetup like when you first got it and all channels should then reinstall.
May 23, 2009 | Panasonic DMRES20D DVD Recorder
I have a HP Photosmart 1000 printer and don't have CD to install
all you have to do is go to hp's web site and download the driver cd there its free and easy.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 01, 2009 | HP DeskJet F380 All-In-One Printer
GE Refrigerator Temperature Control Wr9x521 Logo
54 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
