Tx394 am fm stereo
Trying to record
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
I just came home with the sherwood am fm stereo reciever model no rx-4109 and connected speakers, but no sound is coming out
turn the unit on
press a button for am or fm
select a station frequency
still not working take it back for a warranty check / replacement
AFTER you have read the operatiors manual
Jan 24, 2017 | Sherwood Audio Players & Recorders
Buzzing sound in my car speaker after installing stereo with install kit
That is alternator noise install a 12 volt noise filter inline with the power to the deck.
Jun 28, 2017 | XO Vision XD103 FM and MP3 Stereo Receiver...
No stereo signal from FM? I have had this receiver for several years. I have tried several times to get a stereo FM signal. I have tried a "T" shaped antenna, an "S" shaped antenna...
Appears that your multiplex circuit in receiver is fubar. Also make sure that your receiver is set to the Stereo mode since the mono mode will also turn off the tuner stereo section.
Jun 17, 2017 | Pioneer VSX-D811S Receiver
Iriver e10 how to record radio
http://www.osnews.com/story/17860/Review:_The_OGG-Compatible_iRiver_E10
After you long press the right arrow button the special menu appears: Record, Saved FM Recording, FM Recording Quality, Save Preset, Stereo/Mono, Auto preset, Tuner region. The FM Radio works very well, it has amazing reception compared to cellphones with FM support, but it won't continue playback while you are reading a text file. You must stay in the FM app to have it activated.
May 19, 2008 | iRiver E10 Digital Media Player
Philips SAA7130 TV Tuner
Driver you have is not compatible! try to down load a newest version!!! and look on sound manager if mute is off
Jan 21, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Old jvc home stereo
FM stereo will need a good aerial to work properly, but AM doesn't. If you have not got a good aerial, stereo will stay off. Though you might still here the station. It needs a lot of signal to make the stereo light activate. If was to come on in the weak state the sound would be full of interference. So the set keeps it switched off.
Oct 05, 2017 | Audio Players & Recorders
74 people viewed this question
 Grubhead
Grubhead
