Question about Tefal By Jamie Oliver Bl523d34 500 Watt Blender, 1.5 Litre
Leak The removable blade unit does not seal properly. It probably needs a new (or simply a better) rubber gasket. Where can I get one?
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
What can I do about my Vita-Mix Blender which leaks at the bottom?
You will need a special wrench to remove blade assembly.
then the gasket/seal is inexpensive.
you can check here:
Contact Us Customer Service Vitamix
or check here:
Vitamix Wrench
Apr 25, 2014 | Vitamix 34000 Blender
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Mar 15, 2011 | GE Blenders
Rubber washer for Model TSK-9368AP Blender
I just fixed mine with a rubber hose washer. I had to cut the washer in half because it was too thick, but it stopped the leak!
Mar 29, 2010 | Blenders
Oster 6700 Gasket O-ring leaks
Gasket is not the problem.
Square shaft that is pressed into the turning gear is not tight and allows leaking through the connection.
Only repair is to replace the assembly with the gear drive, blades, etc. and this will take care of the leak. The "O" ring gasket is fine and holds the liquids. However the leak is around the center of the shaft that goes through the bottom.
Regards,
Gary
Jun 06, 2009 | Oster 6700 Work Top Blender
Leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Apr 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
I have a K-TEC HP3 blender (2004 model). The jar started leaking bellow the blade. I tried to take out the blade and seal out, could not figure out how to. Any help is appreciated.
Usualy there is a rubber ring araound the bottom of the blade. If it gets worn out or out of posistion it may start to leak. Also if you dont have everything screwed in tight enought it could leak as well
Jan 01, 2009 | K-Tec Champ HP3 Work Top Blender
Can't separate blade unit from jar, but managed to make it leak
Put it in hot water for a few minutes and then try to unscrew it.
Dec 31, 2008 | Blenders
Maximatic EBL-1000 Elite Cuisine 10... Problem:
Brandy,
-the gasket is a flat rubber ring
-it is used to seal the space between the glass carafe and the plastic carafe base that fits into the base unit
-so the order is glass carafe, chopper blade, gasket, plastic ring...turn this on tightly
-place the whole carafe unit onto the base unit
NOTE: it does not fit firmly...suggest that you hold it firmly before you turn the unit on
so I hope that `fix-ya` works....if not...then ask.
...as any rating than this actually lowers my rank...just the way fix-ya works
bearb
Nov 10, 2008 | Maximatic EBL-1000 Elite Cuisine 10 Speed...
Tefal By Jamie Oliver Bl523d34 500 Watt Blender, 1.5 Litre Logo
41 people viewed this question
Top Tefal Blenders Experts
eyecam
Are you a Tefal Blender Expert? Answer questions, earn points and help others
