Question about Wagner Spray Tech 1999 Dodge Caravan Brake Pad Set Wagner, 99 Dodge Caravan
Rear wheel hub weel not come off
Ereal wheel removal
    Top Expert:
  • Wagner Spray... Master
  • 9,098 Answers
Posted on Aug 29, 2015
Mercedes c 200 n/s rear wheel hits wheel arch i curbed it ever since ive had that problem
if its touching the arch could be a few things if its been curbed broken spring weel shock absorber worst case pulled the bearing out sligtley or any one of the arms going from subframe could be bent or broken it shouldn't be putting it self right when it gets bumped again I would be carful as you could loose the wheel eventually would start with checking the rear wheel bearing and hub also get the rear lower bushing checked as I said could be anything hope this helps ivan
Mar 21, 2013 | Mercedes-Benz C-Class Cars & Trucks
Where the hell can I get a FREE PDF download for my Ford fusion 2 for the removal and replacement of the rear wheel bearings as well as the torque settings for the final nut after replacement.All the so...
Rear Suspension - Rear Wheel Bearing Fusion 2002.75 (06/2002-)
-Removal and Installation
Special Tool(s)
Installer, Differential Bearing
205-062
Installer, Input Shaft Seal
307-210 (17-041)
General Equipment
Soft faced hammerWooden block
Removal
CAUTION: The brake drum and hub assembly removal in this procedure is for installing a new wheel bearing, not for access to brake system components.
-All vehicles
Remove the dust cap.
Remove the wheel and tire.
For additional information, refer to: Wheel and Tire (204-04 Wheels and Tires, Removal and Installation).
-Vehicles with rear drum brakes
Release the parking brake.
Remove the brake drum and hub assembly.
Remove and discard the wheel hub retaining nut.
-Vehicles with rear disc brakes
Remove the brake disc.
For additional information, refer to in this section.
Remove the wheel hub.
-All vehicles
Remove and discard the wheel speed sensor ring (brake disc shown).
Remove the circlip (brake disc shown).
Using the special tool, remove and discard the wheel bearing (brake disc shown).
-Installation
-All vehicles
CAUTION: Support the wheel hub assembly on the wheel mounting face and not on the wheel nut studs.
Using the special tool, install the new wheel bearing (brake disc shown).
Install the circlip (brake disc shown).
CAUTIONS:
Make sure the wheel speed sensor ring is not knocked, damaged and kept free from metal fragments.
Protect the face of the wheel speed sensor ring with a non-ferrous flat block to prevent damage.
Make sure the wheel hub or brake drum is adequately supported and do not allow it to rest on the wheel studs..
Make sure the wheel speed sensor ring is pressed on slowly and squarely until fully seated.
Do not exceed a maximum load of 10 kN.
Using the special tool, install a new wheel speed sensor ring (brake disc shown).
CAUTIONS:
Avoid impact on the wheel speed sensor ring.
Make sure the wheel speed sensor ring is clean.
Avoid any contact between the wheel speed sensor ring and a magnetic surface.
Rotate the wheel hub assembly 10 times counter-clockwise when tightening the wheel hub retaining nut to prevent damage to the wheel bearing.
NOTE: Install a new wheel hub retaining nut.
Install the brake drum and hub assembly.
Apply the parking brake.
CAUTIONS:
Install the wheel hub retaining nut.
Install the brake disc.
-All vehicles
Install the wheel and tire.
NOTE: If the dust cap is damaged a new dust cap must be installed.
Using a soft faced hammer and a wooden block, install the dust cap.
There is no real torque settings for the rear wheels, except to say, do not over tighten or you will stretch the lugs and the will loosen over time.
May 28, 2011 | Ford Fusion Cars & Trucks
Procedure for replacing rear whl brgs on a 2003 escape awd
4-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Rear wheel
    • Rear brake shoes
    • Rear halfshaft nut and loosen the halfshaft from the hub
    • Wheel hub and place it in a vise
    • Inner wheel bearing race from the hub
    • Antilock Brake System (ABS) sensor bracket and move the sensor aside, if equipped
    • Parking brake cable from the steering knuckle
    • Brake line from the wheel cylinder and support the knuckle
    • Lower shock absorber nut
    • Lower ball joint by holding the ball joint stud
    • Upper ball joint
    • Coil spring while noting the location of the insulator
    • Steering knuckle cam
    • Steering knuckle
    • Snapring and press out the outer wheel bearing race from the knuckle
      Rear hub and bearing
      Click to Enlarge
To install:
  1. Install or connect the following:
    • New wheel bearing into the steering knuckle
    • Snapring to the knuckle
    • Wheel hub
    • Steering knuckle cam and hand tighten the bolt
    • Coil spring
    • Shock absorber lower nut. Torque the nut to 85 ft. lbs. (115 Nm) for 2002-04 models; 129 ft. lbs. (175 Nm).
    • Upper ball joint. Torque the nut to 76 ft. lbs. (103 Nm).
    • Lower ball joint. Torque the nut to 76 ft. lbs. (103 Nm). Align the steering knuckle cam and torque the bolt to 85 ft. lbs. (115 Nm).
    • Brake line to the wheel cylinder. Torque the brake line bracket bolt to 15 ft. lbs. (20 Nm) and the brake line fastener to 11 ft. lbs. (15 Nm).
    • Parking brake cable to the backing plate. Torque the bolt to 16 ft. lbs. (22 Nm).
    • ABS sensor bracket. Torque the bolt to 80 inch lbs. (9 Nm), if equipped
    • Halfshaft nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake shoes
    • Rear wheel
  2. Fill and bleed the brake system.
  3. Check and adjust the wheel alignment as needed.
2-Wheel Drive
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Snapring
    • Wheel bearing outer race from the knuckle
      Rear hub removal
      Inner wheel bearing removal-rear hub/bearing
      Rear wheel bearing removal-2wd
      Rear wheel bearing removal-4wd
To install:
  • Wheel bearing in to the knuckle
  • Snapring
  • Wheel hub into the wheel bearing
  • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
  • Brake drum
  • Rear wheel
    Rear wheel bearing installation
    hope this helps if so send testimonial comment or even any other questions you have
Jan 16, 2011 | Ford Escape Cars & Trucks
How to replace rear wheel bearing on 2003 hyandia sonata
Hub & Bearing Removal & Installation To Remove:
  1. Release parking brake.
  2. Remove rear wheel assembly.
  3. Remove rear wheel speed sensor from carrier.
  4. Dismount brake caliper and support with mechanic's wire.
  5. Remove brake disc.
  6. Remove 4 axle hub mounting bolts. Special tool 09432-11000 (Typical) hyundai-08-00-6021.gif
  7. Using tool 09432-11000 (or suitable gear puller), remove tone wheel.
  8. Remove carrier.
  9. Remove stakes and remove flange nut.
  10. Support bearing outer race flange and press rear axle hub out.
  11. Using tool 09432-11000 (or suitable puller), remove inner race from axle hub.
To Install:
  1. Apply thin coat of grease to bearing contact surface and hub.
  2. Using and appropriate tool, press bearing into hub. CAUTION
    Do not press against outer race of wheel bearing.
  3. Install flange nut and stake nut until it meets concave portion of spindle.
  4. Install carrier.
  5. Use an appropriate tool to press tone wheel.
  6. Install hub/bearing assembly with rounded portion of outer race facing up.
  7. Install 4 hub/bearing assembly bolts and rotate hub to seat bearing.
  8. Measure wheel bearing starting torque with a spring balance or equivalent device.
    • Starting torque should measure 15.9 in lb (1.8 Nm) or less
  9. Install brake disc.
  10. Mount brake caliper.
  11. Install rear wheel speed sensor to carrier.
  12. Install rear wheel assembly.
Oct 28, 2010 | 2001 Hyundai Sonata
Trying to remove and replace the right rear wheel bearing on a Hyundai xg 300 2001 model
you have to remove the caliper first than your disk brake(this is a hub assembly) on the back of the weel bearing you should have 3 big bolts remove them put a chain on 2 of the stud of the weel put back the nut on them (if you don't have the tool to do it)than take a steel bar and do like a (slege hammer) just few hit it should come out!..hope this will help you. lipak!...
Mar 29, 2010 | 2001 Hyundai XG300
How to replace rear wheel bearings
don't have topaz. maybe escort will help guide you.
Section 04-02: Suspension and Wheel Hubs, Rear 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Wheel Bearing and Hub Assembly NOTE: Wheel bearings are not serviceable and should therefore be replaced as an assembly with the wheel hub (1104).
Removal
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
  1. Remove the hub grease cap (1131) from the wheel hub.
  1. If equipped with disc brakes, remove the rear disc brake caliper (2552) and rear disc brake rotor (2C026). Refer to Section 06-04 for the removal procedure.
  1. If equipped with drum brakes, remove the two brake drum screws and the brake drum (1126).
  1. Unstake the rear axle wheel hub retainer (4B477) securing the wheel hub to the rear wheel spindle (4A013). Remove and discard the rear axle wheel hub retainer.
  2. Remove the wheel hub from the rear wheel spindle.
Feb 06, 2010 | 1990 Mercury Topaz
How do you remove the backing plate from an '05 Chev Venture rear hub so the hub can be replaced?
The 4 Bolts that Hold the HUB in Also Hold the Backing Plate
Hub Replacement - Rear (Front Wheel Drive/Drum)
Removal Procedure
  2. Remove the tire and wheel.
  3. Remove the brake drum.
    1. Remove and DISCARD the wheel bearing/hub bolts.
    2. Remove the wheel bearing/hub.
    3. Disconnect the wheel speed sensor electrical connector (2).Installation Procedure
    4. Connect the wheel speed sensor electrical connector (2).
      1. Install the wheel bearing/hub. Caution: These fasteners MUST be replaced with new fasteners anytime they become loose or are removed. Failure to replace these fasteners after they become loose or are removed may cause loss of vehicle control and personal injury. Notice: Refer to Fastener Notice in Service Precautions.
      2. Install the NEW wheel bearing/hub bolts.
      1. Install the brake drum.
      2. Install the tire and wheel.
      3. Lower the vehicle.
Nov 07, 2009 | 2005 Chevrolet Venture
How to install wheel bearing hub assemble (front)1998 on a ford escort
front or rear?
Assuming rear, on the brake drum:
Hub Removal
  1. If equipped, remove the brake drum (1126) ; refer to Section 206-02 . If equipped, remove the rear disc brake rotor (2C026) ; refer to Section 206-04 .
  1. Remove the wheel hub.
    1. Unstake the rear axle wheel hub retainer.
    1. Remove the rear axle wheel hub retainer and discard.
    1. Remove the wheel hub (1104).
Nov 05, 2009 | 1998 Ford Escort
How to change a rear wheel bearing on a 1994 toyota camry
The rear wheel bearing on a toyota camry is replaced by replacing the wheel bearing and hub as a unit. this is a design change as compare to older models with two piece wheel bearings. Scotch drive wheels. Remove rear wheel. Remove rear brake drum. (note: if emergency brakes are applied you will not be able to remove brake drum) Remove dust cap and hub retaining nut. Hub should slide off as unit. Replace hub with new unit. Installation is reverse of removal.
May 30, 2009 | 1994 Toyota Camry
Mazda Tribute 2005. 172000 km. Vibrations
Could be ball joints loose...jack up wheel and check for play
Could be bad hubs...the metal part of the tire wheel...i had this problem once..check for obvious damage like a dent or cut in metal
Could be caliper sticking
Could be mud in and around the wheels
Dec 20, 2008 | 2004 Mazda Tribute
Wagner Spray Tech 1999 Dodge Caravan Brake Pad Set Wagner, 99 Dodge Caravan Logo
400 people viewed this question
Top Wagner Spray Tech Air Tools & Compressors Experts
ray gallant
Arthur Cowgill
Level 1 Expert
Tom Chichester
Are you a Wagner Spray Tech Air Tool and Compressor Expert? Answer questions, earn points and help others
