Question about Sony CDX-L510X CD Player
The radio will not turn on
There seems to be no power to the radio
Power windows and radio just quit working?
they should be under the dash but sometimes it can be a different name or more then one thing is run by same fuse escpecially on a newer vehicle
May 26, 2013 | 2002 Ford Explorer
KD- R538 radio wont turn on
Make sure you are getting power to both the red and yellow wires. Red is switched or ignition and yellow is constant and controls the memory of the radio.
Feb 12, 2012 | JVC Car Audio & Video
Job site radio work turn on seems there is no power going to radio. When plug in there is no sign of power in the radio. I have replaced the cord end and that didn't help.Any ideas?
probably the transformer, if it works on the battery but not plugged in thats the most likely cause. I have the same problem and will repost if the transformer replacement works. Cheers
Oct 02, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
It keeps turning itself off! How do I keep it going 24/7?
Well that seems like a waste of energy.
Anyway that is your problem.
The Power/Sleep button has a dual function: Power ON/OFF and Sleep.
A short press will turn the timer on and you will see numbers like 90, 75, 60,...10, 01. pPressing again will cycle to the next sleep duration. If your radio has a short duration timer it will seem that it is turning itself off.
To activate a normal Power up, your first press should last longer (I cannot tell you how long, you will have to try it on your own.) You should not see the timer durations, just the frequency of the station its was last tuned to. In addition, no loudspeaker should be displayed at the lower right corner.
Sep 03, 2010 | Grundig S350 AM/FM/SW Radio
Radio and heater fan seem to be shorting each other out
It does seemed a problem with the wiring. Check for any loose connection or bad insulation.
Dec 06, 2009 | Computers & Internet
How do you program in the frequency
There is no programming on this radio. With power and an antenna connected, turn the power on and you should see a channel number in the display. Turn the volume up about 1/4 of the way, and turn the squelch down. You should hear either transmissions or noise. If all you get is silence, the receiver section is "fried." If the unit does not power up at all (no lights/displays at all) then you most likely have a blown fuse - a simple fix.
Jun 24, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Can't turn it off
sounds like the power button rubber has degraded . please dismantle the radio and clean the button contacts with mild solvent. use nail polish remover to accitone. Don't use soapy water.
Sep 01, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
Acer 3003LCi - Wireless Connection
It seems the two oval lights on the front of the Acer TravelMate 3003LCi are not only lights to indicate WiFi traffic, but also buttons to turn the WiFi radio on and off for security reasons. If you press and hold the left side button for 3-5 seconds it should turn back on the WiFi radio. Windows XP (and maybe other OS’s) have a power saving function that turns the radio off when not in use to save the battery, so you have to use the buttons to turn the radio back on. Seems like a pain in the @$$ to me, but it’s a clients laptop not mine so he will have to live with that.
I hope this helps someone so they do not have to go through the frustration of trying to figure out why the radio has been turned off.
Oct 19, 2007 | Acer Aspire 3003LCi Notebook
Sony CDX-L510X CD Player Logo
20 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
