Question about Sharp LC-15AV7U 15 in. LCD Television
Delete a ._slide file
Slide show gets stuck
Play coolpix s230 video files
First of all, do not use that memory card until this file is properly recovered (take the card out of the camera). See the following video of a freeware recovery solution (PhotoRec). Recommend this program instead of what you used for recovery. PhotoRec is s usually very accurate in file recovery, including videos. This link shows where to get it with additional info on how to do it.
Jan 16, 2012 | Nikon COOLPIX S230 Digital Camera
I downloaded an e-mail in the slide show format. It had background music. When finished I deleted the e-mail but the music continues 2 days later!! I do I get the music off? I have also deleted it from...
Have you tried Restarting your computer?
Restarting the computer should delete the song/file that contains the music out of the Temporary memory in your computer. Try that (if you haven't).
Thanks for using FixYa.
Aug 07, 2011 | Sun OpenOffice
I cannon figure out how to add music from my computer to the slide show....please help me....I have 5 songs on my desktop and I cannot seem to figure out how to get them to slideshow...
Best jbannon257
There could be a number of reasons why you're having trouble adding music files to your slide shows. First I'll lay out the procedure and afterwards I'll give some hints / a link to individualsoftware.com where problems with audio files are discussed.
The procedure (adding music files using SlideShow Expressions):
The programme opens and you are automatically in tab 1: "Add Media".
Click on "Create New Slide Show". Click on "Add Photos"; tell the programme where the photos are, select them, insert them, change their positions if necessary.
Now:
1. Click on "Next" at the bottom of the screen.
2. At "Soundtrack", click "Select Audio Files", then tell the programme where the music files are located on your computer, click to highlight a specific music file, click on "Open". The music file you selected now appears in the Soundtrack window. Repeat this until all the music files you want appear in the Soundtrack window. (You can delete any of them by clicking to highlight any specific file and then click on the little rubbish can icon.) As you go along, the total audio time for the slide show / chapter is displayed as well as the "Duration of Slide Show".
3. In the "Duration" section, you have the option to set the length of time you want per slide (seconds) - usually 8 to 10 seconds is best. (All your slides will follow this instruction; you can't set the duration of individual slides to a different time.) At "Auto-Fit to Soundtrack", you alter the duration of the slides to fit the length of the soundtrack. (This cancels out the previous seconds-per slide setting.) You must therefore choose music tracks that, when added together, will approximately span the whole length of the slide show and then you can fine-tune this by clicking the "Auto-Fit to Soundtrack" option.
4. When you are satisfied with your choice of music tracks and the length of your slide show, click on "Finish".
Issues with music files when using SlideShow Expressions
A.
According to the User Guide (section 3-3) - included on the install disc as a pdf file - the supported audio formats are: mp3, wma, wav, ra. Make sure that your computer also meets all of the requirements (on the box).
B.
Photo & Video Expressions is not compatible with audio files that have been protected by Digital Rights Management (DRM) functionality. Most audio files purchased online through Internet music retailers like iTunes, Urge, or Rhapsody are encrypted with some form of DRM. Similarly, audio files that have been extracted from a CD or DVD (the process known as "ripping") using certain media applications (iTunes, Windows Media Player, etc.) often have default settings that encrypt the files extracted.
There is no way to used DRM audio files purchased from online music retailers with Photo & Video Expressions. However, if you want to used music and audio files that you have extracted from your CD collection, then all you have to do is change the ripping setting in your media application before you extract the files to your computer.
Go to the following site to read about how to change your ripping settings:
http://www.individualsoftware.com/support/frequently_asked_questions.html
Type your question OR (below):
"Photo & Video Creativity": choose "SlideShow Expressions" from drop-down menu, click "Go".
A window appears with options on problems, e.g. "Why aren't my audio files showing?"; "Why won't my music files work?" Click to read.
The best of luck to you. From: 11407336.
PS. Try individualsoftware.com
May 30, 2011 | Individual SlideShow Expressions
Is there a limit to how many slides can go into a slide show -- it keeps deleting slides after 85 --
Best debidell
That doesn't sound right. I've definitely made slide shows of 100 slides and more and burned them successfully too. I usually create projects divided into chapters of about 50 photos each, though, for example, my largest project so far: about 460 photos - 5 chapters of 50 photos each on disc1; 4 chapters of 50 photos each and 1 chapter of about 10 photos on disc 2. However, I have also burned projects that only had one chapter (i.e. one slide show icon on my menu page), for example one with 105 photos.
What you're reporting sounds strange. Do you mean that the slides get deleted during the burning process (that it is only missing from the burned disc), or do you mean that the slides get deleted while you're still compiling the show? However, I recommend the following:
1. If you don't mind breaking your slide show up into smaller parts (chapters), create a show containing about 50 slides, then another with 50, etc. For each slide show you would click on "Create slide show" and each would have its own chapter icon on your menu page. These slide shows will then run continuously, the one following the other. The benefit is that you (or the person the project is meant for) can then more easily access a specific area or slide in your project if so prefered, but also, breaking up your project into smaller parts seem to assist the burning process.
2. Contact the technical support team for SlideShow Expressions at individualsoftware.com. They've helped me out in the past and will get into touch with you within 48 hours of stating your case. You have to register your product with them before you can get help (computer and programme particulars, etc.), but it doesn't take all that long and it really is worth trying out. Don't hesitate - it is a FREE service. They can respond via email or even phone.
I've picked up a few pointers along the way when it comes to SlideShow Expressions:
a) Large photos (1MB and more) can disrupt the burning process - a classic symptom being that the burning process stops during the actual writing of the files (step 5?). I have successfully burned projects containing photos of 1MB and more, but often this is the reason why burning might fail or you end up with a defective end product. Don't be afraid to resize your photos. Yes, it takes up valuable time, but experimenting with photo sizes can save a project. I've been using Microsoft Office Picture Manager to resize my photos to about 400 / 500 KB per photo (or even smaller), but in the end you have to see what works for you. Look, if 1MB or larger works for you, go for it. But there really is no visual difference in the end product: I cannot tell that I'm looking at resized photos and nobody else will either. Of course, I like to add a second disc (CD-ROM) to my projects, containing the original photo sizes so family members can use these for printing, etc.
b) One of the things that make SlideShow Expessions so successful, is the fact that you can make quite lenghty projects. This however, may lead to issues resulting in failure to burn correctly (or even at all) to disc. It helps to divide your project into chapters.
c) The option to also archive your photos and music files on the disc is a great feature, but it has been linked to burning failures, especially when your project is very large / your photos are quite large (a and b).
d) When including video clips in your project, be sure not to use files that are very large. The end product may work well on computer, but it may also cause problems when that same disc is viewed on TV, as some DVD players will not be able to handle large video clips.
I hope all of this can be of help. Do contact individualsoftware.com should this issue persist. I wish you all the best.
May 14, 2011 | Individual SlideShow Expressions
Touch scree is stuck
First you turn off the phone, if it is not turning off, then it means you will have to remove the battery wait a little while and insert it back in the phone and power it on. It will work normally once again, but be sure to reduce the loads on the phone, once you have too many files on the phone, it will continue to get stuck. I will advice you check for the file that you do not use on the phone and delete then so the phone will no longer be getting stuck. To start with, check for your downloads and file transfers for any file that is too large, then delete all unnecessary files from the phone, that way the phone will work effectively without getting stuck.
Hope this information helped.
Jan 09, 2011 | Samsung Star GT-S5233 Cell Phone
Deleting a file from desktop .
  • Restart the computer and try to delete it.
  • get in to safe mode and try delete it.
  • Disable all the sevices and try to delete it.
  • try to delete it from command prompt.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Feb 28, 2009 | Microsoft Windows Vista Ultimate Edition
My last print job gets stuck deleting in the queue!
Go to C:\Windows\System32\spool\PRINTERS on your PC and you will see two files listed fior each of the outstanding print jobs. These will have the file extensions .SHD and .SPL
You need to delete both of these files then power off and power on your printer to be able to continue printing.
Feb 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
How can I see a Microsoft Power Point slide show, size 3.30MB ?
Unless your picture frame supports Power point files you can't load it straight on to it, but you could try this.
  1. Open the powerpoint file in MS Powerpoint (or download the free powerpoint viewer)
  2. Use the Print Screen button (also marked PrtSc) to copy the screen to the clipboard
  3. Paste into a picture program (such as MS Paint, free with Windows)
  4. Save the files as a JPEG
  5. Load these onto the picture frame
Hope this helps
Jan 20, 2009 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
I'm trying to delete a print instruction. Printer shows "deleting" but the delete isn't happening
Click Start - Run
Type CMD - hit Enter
Type NET STOP SPOOLER
Goto C:\Windows (or WinNT) \System32\Spool\Printers
The files in there are your stuck print jobs - delete all of them
Back in your CMD window type NET START SPOOLER
Done.
Oct 04, 2008 | HP Office Equipment & Supplies
I cant delete files from my Sandisk M250 mp3 player
Just called Scan Disk if the device got a setting wrong:
Turn the Scan Disk on:
Go to Setting;
Select USB
Change the selection to Autodetect
Go back to Windows Media player the songs should show up..Worked for me.
May 18, 2008 | SanDisk Sansa m250 MP3 Player
Sharp LC-15AV7U 15 in. LCD Television Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
