Question about D-Link DI-524 4 Port Wireless-G Router - RETAIL (DSDLDI524)
I have a D link DI 524 802.11g/2.4GHz wireless router which I've
I have a D link DI 524 wireless router which I've used for 4 years. We recently moved my pc and now my laptop and daughters pc says we are connected but we can't connect to the internet???
  • mlou38 Jun 14, 2009
    I have tried connecting to the internet using cable and it did connect. So how do I go about configuring the d link settings?
    Novelist:
  • D-Link Expert
  • 199 Answers
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
Posted on Jan 06, 2017
Benimur
  • 6966 Answers
SOURCE: Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
Posted on Aug 17, 2007
sandrew
  • 2961 Answers
SOURCE: D-Link DI-524 AirPlus G - Laptop Cannot Connect to the Internet
Go to control panel>network connections, right click, then properties, then click the TCP/IP line, properties again and ensure that 'obtain ip address automatically' is ticked, click ok,  then close down the window, right click on the network icon again and then properties, then view wireless connections.
Any that appear in this list including your own if it shows need to be deleted, then when you close the window a pop up should appear in the task bar saying wireless networks detected, click the bubble then highlight your connection, click connect and if security is turned on you will be prompted to enter the passkey.
In the routers settings ensure that DHCP is enabled to allocate ip addresses automatically, then reboot the router if neccasary.
Posted on Oct 22, 2007
  • 171 Answers
SOURCE: DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Posted on Jan 25, 2008
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
mail2pvs
  • 390 Answers
SOURCE: vio and d-link wireless router dsl-2640u connection problem
hi
firstly check to see if the wireless is set for wireless access based on MAC address filtering
also check to see if both the laptop and the wifi router are communicating on the same channel
Posted on Jun 24, 2009
I recently moved home. With it came a new phone number , i keep my old router. How do you change the password on a d-link router on talk talk?
Here is the manual. It will walk you step by step through it.
http://static.fixya.com/Manuals/D/D-Link/D_514_Wrlss_1981238F7B7220C756123774F35BCD70.pdf
Sep 15, 2010 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI-614+ is causing Comcast Internet to boot wired user off internet every 45 minutes. It is also asking Iphone wireless user to put the password in every time Iphone user connects.Problems only...
YOU CAN TRY TO UPGRADE THE FIRMWARE OF THE ROUTER.
YOU WILL NEED TO DOWNLOAD THE LATEST FIRMWARE FROM THE MANUFACTURER'S WEBSITE.
DOWNLOAD THE CORRECT FIRMWARE FOR THE CORRECT MODEL NUMBER AND THE VERSION NUMBER
CLICK HERE FOR MORE INFO
Oct 23, 2009 | D-Link AirPlus DI-614+ Wireless Router
Driver lost
You can go to the store (like best buy or even shopo-ko maybe) and go to their computer section of the store then look in the computer gameing area and it should be in there... :)
Dec 27, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-link wireless internet
It is always a good thing to start the different peripherals in an order. First, you start your modem. Wait 30 seconds. Then, start the router; wait another 30 seconds; then the computer.
Aug 24, 2008 | D-Link Wireless Cable/DSL 802.11G Router...
D-Link DI-604 Router can be use in Wireless Broadband?
You can use any wireless access point. If you would like to stay with Dlink, you could try the DWL-2100AP. You would just need to plug it in to an open port on your router.
Dec 28, 2007 | D-Link DI-604 4-Port Cable/DSL Router...
Configuring wireless router
I'm not too familiar with the D-link interface, but I did some research for you & here is a useful link for configuration:
http://support.dlink.ca/faq/view.asp?prod_id=1227&question=DI%2D624
(NOTE: there's a link for configuring DSL PPPoE connections just below step 4.)
Oct 27, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-link DI-624 wireless router connectivity problems (DNS suffix)
Might I suggest that you reset the router to its default configuration by pressing and holding the reset button until it reboots. This way you will be dealing with the default configuration. Then try to use it. Remember the default login ID is admin and the password is Password or admin. Lets hope this helps
Sep 04, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Factory settings
The following is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624S, DI-754, DI-764, DI-774, and DI-784 routers. To perform a reset, please follow steps below: Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset. Step 2 Hold paper clip down for 10 seconds and release. Note: Do not repower unit during this procedure. Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset. Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults. If you have the European version of this router, this procedure may not work. Please consult the D-Link office near you. D-Link USA does not support the European version.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
How do I factory default settings
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
D-Link DI-524 4 Port Wireless-G Router - RETAIL (DSDLDI524) Logo
295 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
