Question about Brookstone HDMI Pocket Projector
Projector bulb blinking rapidly
Can see display of laptop, but violet hue and blinks rapidly. attempted to reset but still same problem
Changed bulb for epson brightlink 455wi but its still blinking red
Is it just one light blinking red or all 3 blinking red? Be sure to 'reset' the bulb hours. Try another bulb. If it is all 3 lights blinking red then you are sol.
Mar 10, 2014 | Epson BRIGHTLINK 450WI Projector
I have a sharp projector RX30X the stand by light still red it doesn't blink and the device doesn't work what's wrong?
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jun 02, 2010 | Sharp REPLACEMENT LAMP FOR XR30X/30S/40X...
Hi. The projector does not display images on
If your using a laptop, you need to make sure your computer port if activated. If that doesn't work, then you'll need to try another cable.
Apr 17, 2010 | InFocus LP70+ Multimedia Projector
Blinking red light
replce lamp ballast board of your projector...
Oct 06, 2009 | Epson EMP 7500 Multimedia Projector
How to change sharp xv-120zu bulb
Jun 07, 2009 | Sharp (RLMPF0005CEZZ) Projector Lamp for...
Unit turns on for 20-30 seconds then powers off.....Please Help
it is the ballast issue,u can try one of the equivalent ones or just try & rework on the old one, perhaps one of the mosfets is leaky!!!!!!!!
Feb 06, 2009 | HP Digital Projector Vp6110 Multimedia...
Projector turns on but no light or image from lens.
The bulbs do not always look broken when dead. You say it is used often. The life of a bulb is around 1400 hours I believe. This normally equates to a year or two depending on your usage levels. Did you notice your image getting dimmer in the months before it stopped working? This would be a good sign it was in need of replacement. Are the lights flashing very rapidly or blinking slowly? If they are flashing very rapidly this indicated the bulb will not fire and needs replacing.
Jan 16, 2009 | Dwin TransVision 3 Plus Multimedia...
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 08, 2008 | NEC VT47 Multimedia Projector
Blinking bulb light
Hi there
You must always reset the lamp timer when replacing a bulb.
Dec 11, 2007 | Dream Vision CINEXONE Multimedia Projector
Brookstone HDMI Pocket Projector Logo
77 people viewed this question
Top Brookstone Office Equipment & Supplies Experts
Tom Chichester
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
