Question about Sony BDP-S350 Blu-Ray Player
Resetting sony 350 bd with no picture
I brought my bd from home where i use hdmi to the fire station where there is a projection tv and tried using component cables and i get no picture but i do get sound. is there any way you can help. for instance i know i can press the home button once then press the left button a few times to get to settings and then down abunch to get to the bottom whre i think the easy set up is located but i dont know where to go from there. thanks.
  • 3 Answers
This is button config for master reset without picture:
Home Left button x 3 Down button x 7 ok (centre button) ok Down button x 6 ok Left button x 1 ok ok wait a couple of seconds for settings to complete, when you switch back on you should have a picture and be back at language set up screen.
Hope this helps.
Please note I am from the UK and I am assuming your menus are the same as mine
Posted on Jun 15, 2009
  • russellc586 Jun 18, 2009
    Sorry, this did not space out correctly when posted, it should have read:
    Just had this problem,this is the button config for master reset when you have no picture:
    Left Button x 3
    Down Button x 7
    OK (Centre Button)
    OK (Centre Button)
    Down Button x 6
    OK (Centre Button)
    Left Button x 1
    OK (Centre Button)
    OK (Centre Button)
    Wait a few seconds for settings to complete, then switch off.
    When you switch back on, you should have a picture and be back at the language setting.
    Hope this is of some use.
2 Suggested Answers
  • 11 Answers
SOURCE: HDMI - no output Samsung P1600 BD
the hdmi output generally needs activating through the menu system. im assuming you havent already done this.
connect it with whatever cable works and navigate through to the menu system to select the hdmi output.
failing that it might be the hdmi cable is an older cable not capable of supporting ver1.3
Posted on Feb 07, 2010
Tv recognizes ps3 through hdmi but ps3 not giving a signal to tv
you could have a loose south bridge chip, you will need to do a re-flow.
also check any small resisters next to the HDMI port.
I’m happy to help further over the phone at https://www.6ya.com/expert/george_c1475a36f7f504e9
Jan 03, 2012 | Video Game Consoles & Games
I can't get a signal between my Sony Blu-Ray Disc/DVD Player and Samsung HDTV monitor. They are connected via a HDMI cable. A brief message on the HDTV reads "Not supported".
First, try to reset resolution of HDMI Sony BD output.
Unplug HDMI cable from TV and change to Component connection to reset BD output resolution.
Than after you entered to resolution menu, choose to standart resolution 720 or 480 i.
If above methode working, try to reconect HDMI cable again to HD TV.
If any problem with picture or still "Not Supported" messege appear, i suggest to change HDMI cable first.
i hope its work.
Mar 14, 2011 | Televison & Video
No picture from Blu-ray
If the TV works fine with other sources the problem is the HDMI output is not enabled on the BD player.
Most BD players do not output both HDMI and composite formats simultaneously. Check to make sure the HDMI output is selected on the BD player and the TV. This information is in the manuals, read the book.
Cheers
Jan 15, 2010 | Hitachi 57F59 57" HDTV
My HDMI connection does not work with Blu Ray DVD player. I have tried a Sony (BDP - BX2 ) model and Samsung (BD-P1590). It could not even display the Home screen for the Sony. The Samsung played for 1 day...
After reading your post a couple of times, it just seems your are in a little of a pickle here. The only thing I can suggest, since your tv will work with fios and not the your BD player(I assuming your using the same port on the tv with the same hdmi cable), is all about firmware. Maybe your tv is not compatible with the the BD player. Try updating the firmware on the tv.
Dec 30, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Video but no audio
This receiver does not support audio via HDMI. You need to connect BD player via spdif cable. Use optical or coax depending on what does the BD player support - receiver supports both.
Dec 24, 2009 | Sony STR-DG520 Receiver
I try to connect my BD player with HDMI port cable from BD player to Sony HT-DDW1600 Theater and from this receiver to TV (40? bravia). When I press BD button on the remote, picture comes out very good but...
Is your sony receiver HDMI pass through? some receivers dont allow audio just video through HDMI. Connect a digital coaxial cable from the dvd to the receiver and you should get true dolby surround.
Oct 28, 2009 | Sony MUTEKI HTDDW1600 Theater System
Sony BDP-S350 - no video..only audio on all outputs
Hope this helps.
May 30, 2009 | Sony BDP-S350 Blu-Ray Player
Hi I have a sony Bravia LCd which has one HDMI socket and that is linked to my sony home theatre , the problem I have is to link my Ps 3 via the the Sony home theatre, it has two inputs and I am connectibg...
What kind of discs r you using? Blu-ray players enforce on the wire encryption called HDCP. I got a call from a customer who was trying to use a cable box and ps3 hooking up to some splitter, then to a single HDMI on the tv. Turns out he was possibly breaking the handshake between the source and the television. Try a non copyrighted video, like a burned copy of a dvd or a home video. and see what happens.
May 01, 2009 | Televison & Video
My HDMI set top box display reads "no input signal" but everything appears connected. I have no picture or sound. Cannot access any tv stations.
Make sure TV is set to HDMI channel.
Try a different HDMI port on back of TV.
Reset the cable/sat box and reset the TV by powering off both and unplugging them for the wall outlet for 30 seconds. Turn cable/sat box on first, and then TV after 30 secs.
If this fails, check the TV manufacturer's website to see if they have any software upgrades that will resolve the HDMI issue.
May 26, 2008 | Televison & Video
Sony BDP-S350 Blu-Ray Player Logo
416 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
