Question about Fan Fever The Goal Light NHL 30 Horn Edition
Light doesn't work
New batteries but does not work
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Battery light comes on. New battery. Alternator tested OK
regulator might be the problem and that is part of the ECM If memory serves me correctly .
Oct 25, 2017 | 2001 Chrysler Town & Country
My Maestro IR remote no longer works after 10 years
The infrared (IR) LED / remote may have stopped working. Since it emits IR light when used, you won't be able to actually see the light with the ***** eye. This makes it difficult, but not impossible to determine if the LED / remote is working or not. You can see if it works by pointing it a night time security camera - the type that has it's own built in IR LEDs to light up the area and does not need visible light to shine on the area (some video cameras can also "see" this light when playing back video taken of an active IR light source). Either record or have someone watch the display while pressing a button on the remote and aiming at the camera. You should be able to do this in broad daylight it will look like a flashlight shining into the camera.
If the LED in the remote is proved to be functioning, the IR receiver in the switch, or some other internal part of the switch may have failed. Since the receiver doesn't light up - there's no way to determine if this is the case without actually replacing the switch. It doesn't matter really, as there are no user replaceable parts in the switch - it either works, or it doesn't.
Ultimately, the best way to troubleshoot will be by replacing components with known good types. Use a battery that tests "good" on a tester, in a new or known to be good remote, used on a new or known to be good switch. You'd would deal with the situation by swapping only ONE component at a time. Once you change the device that allows to circuit to work, replace the new components with the old - except to last one; as this was likely the component that caused the failure.
Try taking the remote to a Home Depot, Lowe's or other similar store with a display of these switches. Do what you need to do to your remote to see if you can control any of the switches/ lights.
Apr 13, 2012 | Electrical Supplies
Alarm went off had to disconnect battery to shut off, door open light stays on, interior light stays on door locks and window controls will not work
O.k. this is a security feature of your alarm the car now essentially thinks that it is being stolen. In order to fix this issue you need to reset the alarm buy reconnecting the battery and using your electronic alarm sensor if you have one (if this doesn't work get new battery for alarm sensor)
Jun 16, 2011 | 2002 Ford F350 Super Duty DRW Reg. Cab
My msi u100 starts up but then the battery light goes red and shuts down how can i fix it
HI Cws666, try to charge your computer for a full 3 - 5 hours without interruptingit, than try again.
If that doesn't work, try buying a new battery.
If that doesn't work send it to computer's brand labs.
Jun 08, 2011 | MSI Wind U100-280US Netbook
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
Battery charge
the battery is dead. that happened to me and i had 3 choices: 1)buy a new dvd player 2)buy a new recharable battery or 3)keep the portable plugged to the wall while i watch movies. i chose number 3 because i usually just use it at places plugs are available. but yeah, the battery is dead.
Jan 27, 2007 | Insignia I-PD720 Portable DVD Player
Fan Fever The Goal Light NHL 30 Horn Edition Logo
53 people viewed this question
Top Fan Fever Sport & Outdoor - Others Experts
Bill Eager
Are you a Fan Fever Sport and Outdoor - Other Expert? Answer questions, earn points and help others
