Question about Holmes Products Dryers
Holmes model HAHV-18
Mounting bushings
Information on replacing the four rubber bushings mounting to the base plate
Hi Kirk
Have you tried the Manufacturers site..
Doubt if any of our guys go that deep
Nov 29, 2015 | Clarke OBS-18 Orbital Sander with Dust...
How I replace just the bushings in a Chrysler sebring 2002
you need a strut spring compressor. remove the strut from the car and compress the spring until its loose from the mounting plate. the you take off the retaining nut and remove the washer, bushing, mounting plate, bushing, washer. the nipple on one half of the bushing goes toward the other half.
Sep 26, 2014 | 2002 Chrysler Sebring
When replacing the alternator on a 2003 VW Passat V6,how do you get the the alternator off of the car. There seems to be no room to get it out
NOTE On A1 and A2 platform vehicles equipped with 010 automatic transaxle, access to the starter motor is limited. Although not necessary, it is recommended that the intake and exhaust manifolds be removed to access the starter.
  1. For safety purposes, disconnect the battery ground cable.
  2. Raise and safely support the front of the vehicle with jackstands.
  3. For A3 vehicles, use a floor jack (with a block of wood on the chock) to support the engine by the oil pan. Do NOT jack the car by the oil pan under any circumstances! The floor jack is ONLY to support the engine while the starter is being removed. The bolts that secure the starter to the transaxle are also used to secure the front engine mount to the transaxle.
  4. If necessary, label the small wires before disconnecting them.
  5. Disconnect the large cable, which is the positive battery cable, from the solenoid.
  6. On 010 transaxle-equipped vehicles, remove the bracket that secures the starter to the engine.
  7. Remove the starter mounting bolts, while supporting the weight of the starter.
  8. Pull the starter straight out from the transaxle.
NOTE On vehicles with a manual transaxle, there is a bushing where the starter shaft fits into the bell housing. If the shaft or bushing are worn or if the starter has been jamming, the bushing should be replaced. There is a special bushing removal tool available but a small inside bearing removal tool is usually sufficient.
  1. Install the starter into the transaxle.
  2. Tighten the starter mounting bolts as follows:
    1. All vehicles except 010 transaxle:
      M8 nut: 89 inch lbs. (10 Nm) M10 nut and bolt: 44 ft. lbs. (60 Nm) M12 bolt: 33 ft. lbs. (45 Nm)
    2. 010 transaxle only:
      Mounting flange bolt: 15 ft. lbs. (20 Nm) Mounting bracket bolt: 18 ft. lbs. (25 Nm)
  3. Attach the electrical connections to the starter.
  4. NOTE: Be careful not to over tighten the battery cable connection. The metal is soft and the threads will strip easily.
  1. Lower the vehicle from the jackstands. Connect the negative battery cable.
Jan 08, 2011 | Volkswagen Passat Cars & Trucks
Need a manual for Holmes Model HM5601.
I have a manual for the Holmes Model HM5601. If you contact me I can make a copy & mail
it to you.
My email is jadamson7@cogeco.ca
Dave
Dec 10, 2008 | Holmes Products HM5601-UC 1.8 Gallon...
Temperature control threshold too high
I have a solution. Let me buy it!! So you can replace it with something that works. I am looking for used
Holmes Heater ModelHFH5506 only and will pay top dollars.
Thanks,
Nov 22, 2008 | Holmes Products Holmes HFH5506-CN Heater...
REPLACEMENT BUSHES
i managed to find a lip underneath the carbon bush
lifted it up slightly and slid out the plastic casing to the side
then replaced the new ones
Sep 21, 2008 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Hepa (HAP223)
Holmes offers its Holmes Odor Grabber HEPA-Type Air Purifier, model no. HAP223-UC2, together with three Holmes HAPF22 Hepa Filters for $29.97 via the directions below. With free shipping, that's $30 off and the lowest total price we could find for this bundle by $33. Recommended for use in room up to 20-square feet, it features air purification and deodorizing. To get this deal:
  1. Add three Holmes HAPF22 Hepa Filters to your cart for $29.97
  2. apply coupon code "H0PVGRAB3" to add the Holmes Odor Grabber for free
Apr 08, 2008 | Holmes Products (HAP223-UC2) Air Purifier
Air purifier
if you want. you can print it off of your computer. you can go to www.jardenstore.com
then click on holmes and in the search bar to your top left corner type in your model number hap424. scroll about two clicks and you will see your unit. click on that picture. then on that screen there will be the manual. it will download in adobe reader. if you have any other questions please don't hesitate to ask.
Feb 21, 2008 | Holmes Products HAP422-UC Air Purifier
Dryers Logo
Top Holmes Products Dryers Experts
Darial Jr Lasaria
Darial Jr Lasaria
Jay Finke
Jay Finke
James Coghill
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
