Question about Koldfront Portable Counter Top Ice Maker White
How to clean model kim202w
How to clean
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
Where is the fuel filter located on a 2000 harley davidson fatboy
To clean the carbureted model's filter, you drain the gas from the tank, remove petcock and filter, clean filter with compressed air, reinstall. The fuel injected model requires that you drain the tank, remove the entire pump assembly from inside the tank, and then replace the filter (it can't be cleaned).
The carbureted model's filter is supposed to be inspected and cleaned every 20k miles. The fuel injected model's filter is supposed to be replaced every 25k miles.
Sep 06, 2014 | Motorcycles
I have the Braun 360° Complete 8985 Electric Shaver, and ive learned that it is pritty much gonna keep being a money hole. Can any one suggest a self cleaning brand that is more reliable?
The self-cleaning shavers are all much more expensive to maintain than traditional non-self-cleaning shavers. Your model 8985 is not inherantly more expensive to maintain than any other self cleaning model by Braun or other brand. The cleaning solution is expensive, the cleaning machines break because of exposure to liquid, and the heads often wear out faster as well.
Because of this, I strongly suggest you buy a shaver without a self cleaning machine. Most models that do not include self cleaning machines are very easy to clean with an old toothbruh dipped in rubbing alcohol. If you liked the way the Braun shaved when it was in good condition, I would suggest the following models linked below as possibilities
http://shaveroutlet.com/shavers/foil-shavers/braun-series-3-370-men-s-shaver.html
http://shaveroutlet.com/shavers/foil-shavers/braun-1775-series-1-shaver-p-123.html
Sep 07, 2010 | Braun 360° Complete 8985 Electric Shaver
Need instruction manual for Optima Model 420
Yes you can re-use the cleaning solution, and you should rinse the item in clear water after cleaning.
Jun 09, 2010 | Watches
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Jul 03, 2009 | Vornado Circulating Fan
How do I start the clean cycle
The "S" in the model number stands for standard clean oven (vs. self clean), so unfortunately, you will have to use a can of Easy Off or similar oven cleaner.
May 07, 2009 | GE 24" Built-in Single Electric Wall Oven...
DO NOT KNOW HOW TO USE SELF CLEAN ON OVEN?
Hi April,
Without a model number, I'm shooting in the dark but I'll give you basic instructions that fit for most ovens, OK?
First off the door has to be locked PRIOR to cleaning. Look around the top of the oven door, there should be a handle (for mechanical models). Rotate this handle from the left to the right to lock it. If there's no handle, that means your oven locks the door by itself when "Clean Mode" is selected.
Now, at the control panel, select "Clean". At this point, you may have options on the length of time it should clean, select 3 hours and hit "Start".
There ya go! Hope this helps. If not, DON'T RATE THIS SOLUTION! Just write back and provide the model number, I'll give you exact instructions with that. Deal? Cool.
SG
Mar 23, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Maytag oven: How to clean
Before you self clean you always want to take a rag with warm water and remove all chunks of food.
Next clean around the frame of the door gasket with the rag(these cant get clean in self clean) do not clean gasket IMPORTANT
Remove all racks and pans
Most older door handle locks require a few buttons, get your model number(which is located either on the frame your bottom drawer shuts on if a single oven, if double is on door frame if built into cabinet walls, if on floor its on back of control panel, a piece of metal thats like a mailbox flag, you turn it to read model from front) and go to www.maytag.com click support then manuals enter your whole model number EXCEPT the last letter. (example if your model is MER6775AWW enter MER6775AW<--only one W) This should bring up use and care guide, which will give step by step instructions, if you follow them and it wont clean, your latch most likely needs replacement
May 02, 2008 | Kitchen Ranges
Koldfront Portable Counter Top Ice Maker White Logo
Top Koldfront Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Koldfront Kitchen Appliances - Other Expert? Answer questions, earn points and help others
