Question about Home
Dropped my don k5462 digital thermometer and it won't change temperature from -58F
The thermometer's ditital display shows -58.0F Degrees and it won't change. How do I reset the thermometer?
SOURCE: Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Posted on Dec 20, 2007
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
SOURCE: model 6312026 Nexxtech 433MHz wireless
Hello, you have to push few second the mode button and after date, hour etc it will be possible to change F for Celsius. He will flashing and after push one of the two button up or down.
Bye from Quebec Canada
Posted on Nov 20, 2008
SOURCE: My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
SOURCE: outside temperature thermometer on 2005 Ford Freestar van
my thermometer is blinking -40 degrees how can i fix this
Posted on Aug 01, 2010
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Why is the rear cylinder overheating
How do you know it is overheating??? What is the temperture???? Take some measurements with a ditital infra red thermometer gun and post some more info etc.
Jun 01, 2014 | 2000 Harley Davidson FLHR-FLHRI Road king
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
How fo I change the degrees from C to F degree ?
Changing the temperature scale Your Braun ThermoScan is shipped with the Fahrenheit (°F) temperature scale activated. If you whish to switch to Celsius (°C) and/or back from Celsius to Fahrenheit, proceed as follows: (1) Make sure the thermometer is turned off. (2) Press and hold down the Start button (IRT 4020) or the «I/O» button (IRT 4520). After about 3 seconds the display will show this sequence: «°F» / «SET» / «°C» / «SET» ... (3) Release the Start button / «I/O» button when the desired temperature scale is shown. There will be a short beep to confirm the new setting, then the thermometer is turned off automatically.
Feb 10, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
I just changed the battery and I keep getting the temperatures in Celsius instead of Fahren. How do I change it to F?
You need to discinnect the battery and reinstall it. When you reconnect the battery press the 'SET' button within 15 seconds. The temperature reading will now be set to Degrees F.
See below.
Setting/Changing ºC and ºF Temperature Scales
The food safety thermometer can display temperature in either the °C
(Celsius) or °F (Fahrenheit) scales. The desired scale is selected at the time
the battery is installed:
Selecting the °C Scale:
When the battery is connected to the battery leads the °C scale indicator
shows on the display for approximately 15 seconds. If the SET button is
not pressed the unit will time out and default to the °C or Celsius scale.
Selecting the °F Scale:
If the SET button is pressed within 15 seconds of connecting the battery to
the battery leads, the temperature scale display will toggle to the °F scale
indicator and the unit will now default to the °F or Fahrenheit scale
Feb 28, 2010 | Fluke Networks Fluke/Raytek FoodPro Plus...
Outside temperature thermometer on 2005 Ford Freestar van
Jan 19, 2009 | 2006 Ford Freestar
Home Logo
187 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
