Question about Vehicle Parts & Accessories
Car thermostat wont get hot
Car heat wont come on
    Sergeant:
  • 462 Answers
Sounds like thermostat stuck open replace it
Posted on Sep 07, 2014
Hoover dryer lights up element heats but machine wont run keeps saying clean filter ?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Dryer Overheats and or Dryer Gets too Hot
Nov 22, 2016 | Hoover Dryers
1996 MAZDA MPV HEAT WONT GET HOT ENOUGH
You need to put a higher temperature thermostat in. Try a 200 degree thermostat and make sure that you have a full radiator. Also you could dilute your antifreeze a little more than 50/50 .
I would also try a 70/ 30 mix. Hope this helps.
Feb 18, 2015 | 1996 Mazda MPV
My heat wont get hot in my 2004 dodge durango it gets warm
check thermostat and make sure heat blender valve is on hot
Jan 10, 2014 | 2004 Dodge Durango
No heat on my toyota pickup 1991
CHECK THE BLEND DOORS ON INSIDE OF TRUCK UNDER THE DASH IFE THE BLEND DOOR IS STUCK IT WONT BLOW HOT AIR
Jan 18, 2013 | 1991 Toyota Pickup
My car wont get hot. got new thermostat and water pump
FIRST THE ONLY REASON FOR A THERMOSTAT IS TO GET HEAT INSIDE THE CAR SO WHAT YOU NEED TO CHECK IS THE HEATER HOSES GOING INTO THE HEATER CORE AND SEE IF EITHER ONE IS HOT IF ONE IS HOT AND THE OTHER ONE COLD OR WARN THEN THE HEATER CORE IS PLUGED IF BOTH ARE HOT THEN YOU HAVE A PROBLEM WITH A VENT DOOR IN THE HEATER BOX
Oct 19, 2010 | 2004 Chevrolet Impala
Tempeture guage not working and heater is blowing out very little hot air on my ford galaxy
you need to get the thermostat changed. The thermostat controls how much coolant runs around the engine and sends signals to your temp gauge to indicate how hot the engine is.
if the thermostat is faulty it wont sent signals to the temp gauge and wont open up to allow coolant to run around the system. Your heating is run by coolant, behind the dash there is the heater matrix hot coolant runs into the matrix which gets blown inside the cab.
Fitting a new thermostat will fix all the heating and gauge problems. if your technical minded you can buy a thermostat from an autofactor (or ford, but they are expensive from ford). a garage will charge about £30-£100 ish for a new one.
hope this helps :-)
Feb 10, 2010 | 2001 Ford Excursion
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
My 99 dodge dakota wont heat new thermostat motor
You have a bad heater valve, operated by vaccuum or cable its on the hot water line on its way to the heater core.
Feb 20, 2009 | 1997 Dodge Dakota
92 acura legend wont blow out heat
Does your car get hot? If so the is a wire connected to your thermostat. It probably came off. Check it.
Jan 19, 2009 | 1992 Acura Legend
Vehicle Parts & Accessories Logo
14 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
