Question about Grizzly Big Bear Atv Maintenance Free Battery
How to install horn
Need to know how to put the horns wiring together
    Sergeant:
  • 462 Answers
Power to switch then from switch to horn other side needs to be grounded usually marked pos neg
Posted on Sep 07, 2014
Car horn wont work. Dont hear the relay clicking. Does anyone have any suggestions?
If the fuse blew, most likely the new one you installed also blew. Check it again. You have a short somewhere. Double check all the wires you did while installing the horn button.
Feb 14, 2016 | 2005 Chevrolet Malibu
How di i install a 4 note horn where there is only one?
just wire up your new ones all together then hook it to the one wire on old horn
Mar 08, 2015 | 1998 Cadillac Eldorado
Wirng diagram for a sc50 sonic pride scooter power switch, horn,horn button,power meter,etc.
Bad boy (or girl of course)! Should have noted everything BEFORE taking it apart. But then you now know that and probably did before .... Oh well, we've all done it... Once. I have a Pride scooter, but not this one. MAYBE someone with a sc50 Sonic will be kind and post a photograph of the underside of their control panel while still wired?? This would help our friend a lot.
Sadly Pride Mobility aren't known for useful things like wiring diagrams or meaningful owner's manuals.
Jun 22, 2014 | Pride Sonic 3 Wheel Portable Scooter
Rodeo wiring diagram
The wire to the horn button is a live wire and it is shorted out when you press the button. This activates the relay and blows the horn. relays normally work by power coming to a terminal through the coil and out the other terminal to earth . This connects the coil and so the contacts are pulled together to allow power from the battery though to what ever is the relay for .. So what you need is power to a coil terminal on the relay and the horn wire connected to the other terminal. This will complete the circuit when you press the horn and the relay will close and the horn will blow.. To get this it may be necessary to piggy back off the power wire ( battery terminal on relay ) to a coil terminal .
Mar 31, 2014 | 2005 Holden Rodeo
Can anyone give me a straight answer on how to wire a horn on a 92" s-10 4x4 Blazer? I`ve gotten as far as taking the steering wheel off and thats it!
no need to take of the steering wheel.. locate the old horn.. then remove it.then put the new horn. if the old horn has only1 wire its ok. then the new horn has 2 wire. just body ground the 1 wire[no polarity] choose any of the 2. to the body gound or join the brack of the horn together.then the other to the original wire of the old horn
Sep 26, 2013 | 1991 Chevrolet S-10 Blazer
Apparent electrical short or wiring trouble.
Check your fuses. Sounds like something in the horn circuit after the switch is shorted.
Jun 07, 2012 | Suzuki Motorcycles
I have a 63 Ford T-Bird that I can't get the horn to work. I have checked the wires and the grounds and they look good. The horns work when I tested them also but when I put the steering column together...
You missed something putting the column back together. IDK the design of the wheel, but if all the wires to the column are good, I'd look at the switch itself in the column. Probably not making contact.
Sep 12, 2010 | Ford Thunderbird Cars & Trucks
On my 1972 duster,when i blow the horn,the fuse blows and the tail lights go out also. the same fuse runs both.what could be the problem?
This sounds like the horn may have a short in it somewhere. Does the horn blow at all? Try this: Make sure you have a good fuse installed to this circuit again. Disconnect the horn and place a volt/ohm meter set to DC volts on the horn connections. If there is just 1 wire going to the horn, put that wire on the red wire of the meter. Put the black wire of the meter to a good ground, preferably the negative battery terminal. Now press the horn and see if there is a reading of around 12 Volts. If so, replace the horn. If not, and the fuse blows again, check the wiring for a fray/short to ground. When you're looking at the horn of course, make sure the positive lead isn't shorting to ground as well.
I hope this helps! Let me know if you need any more assistance! :)
-Jason
Feb 11, 2010 | 1983 Plymouth Gran Fury
I have a 1983 cj7 and am trying to replace the steering wheel, and in the process fix the blinker switch and reconnect the horn. There is a horn terminal, but only one that I see. How is the circuit...
If you found two wires, they both attach to the horn pad on the wheel...Unless there is something wrong with the horn or relay, touching them together should make the horn blow. The pad is two separate plates. When you push on the pad the two plates come together and make contact just like touching the wires together. Hot wire the horn to the battery and test it, then check the horn relay if the horn itself works, but touching the wires together or grounding either of them dosen't work..
Sep 23, 2009 | 1983 Jeep CJ7
I have a 1966 chevy impala and recently installed a billet specialties steering wheel. I am tring to get the horn to work. I tested it and the horn itself does work and i know i need a GM horn wire. My...
most the time on the billet steering wheels you have to put a push button horn. if you ran a wire through column it would spin wire and eventually break it..
Apr 21, 2009 | Chevrolet Impala Cars & Trucks
Grizzly Big Bear Atv Maintenance Free Battery Logo
44 people viewed this question
Top Yamaha Vehicle Parts & Accessories Experts
Andrew Taylor
Andrew Taylor
Coss
Jeff Youtsey
Jeff Youtsey
Are you a Yamaha Vehicle Part and Accessory Expert? Answer questions, earn points and help others
