Question about LG WFT1071TP Top Load Washer
Where i put the sofner
I need to find the liquid dispender for the softner
Hi, I have a hotpont aquarius wml52o washing machine and do not know which compartment to put the fabric softner or washing liquid. The small section on the left is bunged up and will not drain.
The small section is for the softner, you need to take it apart and clean it out thoroughly. If your using washing liquid then you need to put it directly into the wash.
Mar 02, 2011 | Hotpoint Washing Machines
Dispenser - which tray to use for liquid detergent?
Liquid goes straight into the wash before you put it on, you can get a liquid ball that you fill and put in with the wash, dispenser just for powder which goes in 2 or fabric softner.
Mar 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
Inserting detergent/fabric softner/bleach
First check in which tray the water is flooding then put in that tray and then start the main program
May 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a creda simpilcity 1000 which has 3 sections to the drawer, i dont know which i put washing liquid in and which softner?
The smallest compartment is for softner. Or another way is to just pour a small amount of softner into compartment and ensure it stays there for wash.
Mar 15, 2010 | Creda W100FW Front Load Washer
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
Help My front loading washer is not dispending
have you pulled the drawer from the machine and cleaned it thoroughly. break it down into individual pieces and clean the hell out of it. Fabric softener can build up over time and clog every crack and crevice. check also the hole the drawer goes into, water flows into the drawer mixes with f.s., bleach, etc. dilutes it and sends out the bottom.
Jun 16, 2009 | Washing Machines
Last 2 loads didn't use fabric sofner
Top load washer? check the agitator. alot of times the softner will gum up the inside of agitator and make dispensing hard
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag neptune dryer
if your putting liquid softner in the dryer STOP !!!Put liquid softener ONLY in the washer.
May 25, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WFT1071TP Top Load Washer Logo
11 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
