Question about Curtis International Recertified - Curtis 37" 720p 60Hz LCD HDTV LCD3708A
Need main circuit board for curtis tv
Not working circuit board not working
This is a CURTIS 32" LCD that was my mother's."WILL NOT" power on at all. I brought it home to tinker with it; any suggestions??
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 28, 2017 | Curtis Televison & Video
My Curtis tv will not turn on
Mar 12, 2017 | Curtis Televison & Video
We had a power outage and since my tv does nothing, a tiny red light says standby but nothing changes.
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 10, 2017 | Televison & Video
How do I fix my Curtis 32" TV Model LCD3213. It turns on with no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 29, 2016 | Curtis Televison & Video
My Curtis flatscreen suddenly turned off, won't start again. TV is about 3or4 years old
Sep 26, 2016 | Curtis Televison & Video
My Curtis LCD3235a Tv shut off and will not turn back on the red light does not even show up even though everything is plugged in any possibilities of what could of happened or how to fix it?
Aug 07, 2016 | Curtis Televison & Video
Half my tv backlight works and the other half doesn't
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
Mar 08, 2016 | Proscan 50" LCD HDTV PLCD5092A - CURTIS...
Curtis model 1922a keeps turning off
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 25, 2015 | Curtis LCD1992A 19 in. LCD TV
Curtis-Mathis C-2620RC
I would suspect that most A.C. cords could work for this TV. It should be soldered to the main board and not plug in. If you do replace it you need to make sure the polarization is done correctly or a shock hazzard could be present!
Apr 19, 2007 | Curtis-Mathis CM27101S TV
Curtis International Recertified - Curtis 37" 720p 60Hz LCD HDTV LCD3708A Logo
23 people viewed this question
Top Curtis International Televison & Video Experts
Electro Med Services...
Are you a Curtis International Televison and Video Expert? Answer questions, earn points and help others
