Question about Ovens
Wiring diagram smeg a1 timer
Wiring diagram for smeg a1 tiner
Smeg SA530X cooktop elements only half heating
You could be right, But without a wiring diagram and a multimeter, you won't come far. Remember the elements work on dangerous voltages, so if you don't know what to do keep the top closed.
But if you know, it could be worth looking on the underside of the apparatus, sometimes the wiring diagram, with all the essential stuff, like eventually thermostat, regulator lights and so on it.
Jan 17, 2014 | Ovens
Smeg uk60mfx schematic
Check back of the oven or inside control panel. Turn off the power first!
Oct 26, 2013 | Smeg Ovens
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
Smeg oven stopped working
Jan 27, 2012 | Smeg Ovens
Oven fan working. just no heat.
Most common problem will be a faulty oven element. Also check the wiring at the oven element terminals, it could be burnt off.
Feb 17, 2011 | Smeg SE280X Stainless Steel Electric...
Need a wiring diagram for a Smeg Oven SA392EB
I don't know about Smeg, but major appliance manufacturers in the United States generally put a wiring diagram inside the back of the oven, usually either on the back cover or on the back panel of the oven itself. In laundry equipment, sometimes it's folded up or placed in an envelope inside the control panel, but I suspect that would not be the case for stoves because there would be a greater risk of fire.
Dec 16, 2010 | Ovens
Have been told my oven needs a new timer and they're charging £224 for parts and labour is this right?
An oven for this model will cost around 120 to buy see www.shop.ukwhitegoods.co.uk smeg spares/ oven timers
so its not extortionate at 163 fitted
Dec 15, 2010 | Smeg DO81CSS Electric Double Oven
SMEG SA708X oven's symbols have rubbed off, wioul appreciate a photo of the left hand (have only managed to find the dial template for teh right side dial)
Here's a picture of the panel... BTW does anyone know the wiring / have a wiring diagram for the door switch as mine was swapped around by an oven guy just to get it running but now I have a new switch and can't remember how it all goes!!
Feb 26, 2010 | Smeg S1100MFX5 Electric Single Oven
Looking for a wiring diagram for a Smeg Cooker with Gas hob. Model # SNZ91MFX .
hi could you please email me the wiring diagram for a smeg snz91mfx to lukea31@hotmail.com or call me on 0278264558
chea luke frm the conection company
Jan 11, 2010 | Ovens
Ovens Logo
12 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
