Question about LG RU-52SZ30 52" Rear Projection Television
Lg ballast board replacement
I AM FROM CARACAS-VENEZUELA, I HAVE LG REAR PROJECTION LG RU52SZ30 THE TECHNICIAN TOLD ME THAT THE BALLAST BOARD WAS BAD I BOUGHT A NEW ONE FROM SHOPJIMMY LG 6913V00002C, THE MANUAL SAID THAT BALLAST BOARD IS LG 6913V00002A, I GUEST THAT I BOUGHT IS IT THE REPLACEMENT ITEM. THE PROBLEM IS THAT THE CONNECTOR IT DOES NOT FIX WITH THE BOARD OF THE LG TV SET. I WOULD LIKE TO KNOW, FIRST IT ALL, IF THE NEW ONE HAS THE SAME CHARACTERISTIC OF THE OLD ONE AND IT CAN MAKE THE SAME FUNCTION. AND SECOND I WOULD LIKE TO KNOW IF IT WORKS, THE TECHNICIAN CAN MAKE CONNECTOR ADAPTER TO PUT THE TV WORKS. I WOULD APPRECIATE YOUR ANSWER AS SOON IS POSSIBLE edgarescobarhotmail.com
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
Posted on May 12, 2008
russ_hill007
  • 3178 Answers
SOURCE: I was told I need a new lamp ballast assembly. I
so the one first is an LG model ballast but the one in the tv is a phillips one, strange.. can you give me the bord number power side... it is always best to replace old number so the damaged numer one should be the number you use. LG, Philips etc use different part to make the same tv model. e.g one can be made in twain and the other from china. both the same case do the same things but have completely different parts in side. Looking at the parts on line they don't have the same connections or the same voltage so would be a bad idea to try and put the new one in with the wrong number.
Posted on Oct 23, 2013
I was told I need a new lamp ballast assembly. I was also told by someone to order 6913V00002C Ballast (EUC 100 P/11) but when I opened my TV and took out the "bad" ballast, its is a EUC 100 C/00. Anybody...
Oct 22, 2013 | LG RU-60SZ30 60" Rear Projection...
LG RU60SZ30 I have a LG RU60SZ30. I had a technician come out and I was told I need a new lamp ballast assembly. I was wondering if anyone could help me with this process. I opened up the whole back of tv...
need to unscrew or unclip the board and pull out the back. it will be screwed down to the plastic case. and have the wires plugged into it. remove it all and replace.
Oct 21, 2013 | Televison & Video
Recently we replaced the bulb in our LG 52SX4D-UB. Once the bulb was installed we reset the hours for bulb according to the instructions that we reviewed on-line. Once the power button is pushed on the...
Tv goes off and on.It have alots of clicking noise sounds too?Yes.The board that call the Ballast board it is also dead too.The Ballast board only job it is to help to ignite the tv projection lamp.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Apr 03, 2011 | LG 52SX4D 52" HDTV
I was told that my bulb is good however the balast is bad. where can i purchase this and are there instructions on replacing it?
Turn on the tv now,hear alot of clickings?Yes,the Ballast board is dead.The only function of the Ballast board is to ignite the projection lamp.Tries websites like Ebay.com,Partstore.com to buy a ballast board for the replacement.Instructions came with the board,how to replacing it,don't know?Try You Tube.com video.Type in ur tv make,model and the problems.Might have some bodies giving u advises or there are videos tutoring u how to do it.
Oct 12, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I HAVE LG REAR PROJECTION AND IT TURNS ITSELF OFF AT RANDOM IT CAN GO FOR HRS WITHOUT TURNING OFF AND OTHER TIMES IN A HR
Have you replaced the lamp all ready this sounds like you have a bad BALLAST BOARD the ballast board is not working correctly it is not sending enough energy to maintain the lamp on but but sometimes it is able to gather enough to keep on for hours sounds like a bad BALLAST
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 04, 2010 | LG RU-52SZ30 52" Rear Projection...
I have an LG RE-44SZ21RD, turns off after 5 minutes of use
It might be worth checking that you haven't accidently activated the tv's sleep timer, I did on my LG DLP !!. always check the obvious first.
Oct 06, 2009 | LG RE-44SZ21RD 44" Analog Television
LG Rear Projection TV won't turn on
Could be your Ballast Board that fires up lamp or Fan is bad that cools Lamp there is also a Fan mounted up under Light Engine if it stops running set will not come on. CK Fan Behind lamp first if it is OK then replace Ballast Go to E-Bay for Best Deal on that part .
Aug 14, 2009 | LG RU-44SZ51D 44" Rear Projection...
My PT-61LCX65 all of a sudden turned itself off and the Lamp indicator LED is blinking once every 5 sec. It will not power up. Can it be the lamp?
That is most probably the lamp. In some case the lamp is fine and the problem is the lamp high voltage board (ballast board).
The most coomon is always the lamp. The lamp cannot be tested . The ballast board must be tested by a technician.
The normal operation in this case is replaceing the lamp that cannot be tested. then, if you are within that 2% of the cases with ballast problem you replace the lamp power board or call a technician.
You can find parts here.
May 03, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Ballast replacement
May 12, 2008 | LG RU-60SZ30 60" Rear Projection...
LG RU-52SZ30 52" Rear Projection Television Logo
67 people viewed this question
Computer Repairing
Computer Repairing
