Memory Sockets or Slots are the place where memory
RAM modules are inserted in the motherboard. The Acer Aspire Z3731 has
4 (4 banks of 1) memory expansion slots. A memory bank is a group of
memory expansion sockets, a bank must be completely filled with memory
modules of the same size and type in order for the system to recognize
and address the memory. i.e. :
2 sockets (2 banks of 1) This indicates that there
are 2 memory slots. These are divided into 2 banks, and each bank
consists of one memory slot. So you can add memory one piece at a time
for the system to use.
3 sockets (3 banks of 1) This indicates that there
are 3 memory slots. These are divided into 3 banks, and each bank
4 sockets (2 banks of 2) This indicates that there
are 4 memory slots. These are divided into 2 banks, and each bank
consists of two memory slots. So you must add memory two pieces at a
time (they must be the same size and type of memory) in order for the
system to benefit from the upgrade.
8 sockets (4 banks of 2) This indicates that there
are 8 memory slots. These are divided into 4 banks, and each bank
12 sockets (3 banks of 4) This indicates that there
are 12 memory slots. These are divided into 3 banks, and each bank
consists of four memory slots. So you must add memory four pieces at a
time (and they must be the same size and type of memory) in order for
the system to benefit from the upgrade.
Most laptops have 2 memory slots, if you have 1 Gb of RAM using two 512 Mb RAM then you need to replace them with two 1 Gb RAM modules. If you have one RAM module 1 Gb then you only need to add another 1 Gb RAM module. Try to use the same make and speed RAM.
Acer Aspire (NoteBook) 3660 Series
Please see below for the Memory ( RAM ) upgrade options available for the Acer Aspire (NoteBook) 3660 Series.
Memory Details for the Acer Aspire (NoteBook) 3660 Series
Standard Memory :
512MB (Removable)
Maximum Memory :
2GB
Total Memory Slots :
Memory Type :
DDR2 667MHz (PC2-5300) 200-PIN SODIMM
According to Acer's website, your system uses this memory configuration...
256MB DDR2 533/667/800 SDRAM expandable to 4GB
My suggestion to you is, if you have the original 256 loaded, find a good bargain on DDR2 667, one gb memory modules and REPLACE what is installed, instead of adding to it.
If you add to it, and it is the incorrect speed (that's the 667 number), you may experience some very undesirable results.
good luck
tony
PS. This advice is posted assuming you are aware of the dangers of ESD, and you have some technical experience on the inside of a computer. If this assumption is false, please share this advice with your technician to get the correct memory upgrade.
Here is a link that gives step by step with pictures. Be sure to properly ground yourself by either wearing a wrist strap or touching metal surface when handling the module
unplug the power adapter and remove the battery from the laptop
1. Remove the two screws fastening the RAM cover. 2. Detach the RAM cover from the main unit. 3. Pop out the memorys and remove the memorys from the memory sockets.
