Question about Ingersoll Rand 2545 pump,air compressor
Knocking noise very loud knocking noise
  • Ingersoll Rand Master
  • 2,760 Answers
2545 is a piston compessor if so you've got a busted rod on one of your cylinders , this will fail catastrofic and break out side of compessor but if caught early can still be rebuilt with a few new parts
Posted on Sep 27, 2014
Engine noise
No miracle fluid in a bottle is going to fix a loud engine knock. Get it diagnosed
Mar 05, 2018 | Buick Cars & Trucks
99 olds.intruge 3.5 engine
loud knocking internal lower part of engine usually means [ rod knock ] --bad wrist pin -spun bearing -or piston ring]s] --that the worst other can be timing failure --or component failure --you need to isolate the noise and diagnose from there
Oct 01, 2016 | Cars & Trucks
Knocking rattling noise from engine appeared while driving loss lil power running but loud knocking in engine
You didnt state vehicle however if the engine knocks the knock sensor will back off the timing thinking its detination not an actual knock if its knocking loudly stop driving it, something is going to let loose
Oct 06, 2015 | Cars & Trucks
Can lifters be replaced
Oh yea, lifters can be replaced , best if you replace cam an lifters together ! Loud knocking is not usually associated with lifters , they usually make a ticking noise ! Knocking noise is most usually in the bottom of the motor , main or rod bearings . most of the time rod bearings !
Jan 27, 2015 | 1996 GMC Jimmy
Enfine noise
Could be many things. What kind of noise? Knocking, ticking, or just plain loud? Loud could be loose exhaust manifold, cracked manifold, bad exhaust gasket, bad exhaust pipe, ect. Knocks and ticks, squeals and more are different story. If you can't describe it, post a video.
Jun 02, 2014 | 2007 TVS XL Super HD
Loud knocking noise engine
Have a oil pressure test done on the engine to determine bearing failure. Have a compression test done to check for internal damage such as broken rings/pistons or overheated motor.. If the noise appears during acceleration then run the fault codes and look for a tuning problem or failed knock sensors
Sep 20, 2013 | Hyundai Elantra Cars & Trucks
My dryer starting knocking, it knocks loud then gets a little slower then starts loud again.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 09, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Makes loud knocking noise under refrigerater side
Hi, Does this noise accure when the compressor is shuting off?
May 12, 2009 | Whirlpool ED5VHGXM Side by Side...
My Carrier 58dxc is making a loud noise
If your turning on heat and the unit is knocking and blowing cold air, your compressor is having problems in heat mode, could be reversing valve. A tech is needed in your situation. Getting the prob fixed right away will save you dollars..
Dec 02, 2008 | Heating & Cooling
Ingersoll Rand 2545 pump,air compressor Logo
102 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
