Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
Dishwasher is locked out
Can not get dishwasher off locked mode
My dishwasher is stuck on control lock. What do I need to do?
If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds. NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
Sep 21, 2017 | Dishwashers
How to off on kenmore 665 dishwasher mode or reset the panel
Check user manual or call manufacturer. The unit is not timing out.
Mar 08, 2015 | Kenmore Dishwashers
665.1276 locked led
Use the Top Rack Only key and press it for a few seconds to get the dishwasher out of the Lock mode.
Apr 20, 2014 | Dishwashers
Electrolux dishwasher in locked mode
Good Afternoon David - When the light is on, the control is locked and no cycles can be selected or started. To de-select the Control Lock, press and hold the heat dry key or press down on the lock icon for approximately twenty seconds. If issue persists, you may reset the dishwasher by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. The dishwasher should resume to normal operations.
Jun 24, 2013 | Electrolux Dishwashers
Dishwasher will not start. The only light that comes on is the "control lock." Model #: KUDP01DL
Press and hold the control lock key for about 10-30 seconds, or until it goes off. This is the "child lock out" mode.
Apr 27, 2011 | KitchenAid 24 in. KUDP01DL Built-in...
Dishwasher is on locked mode. How do I unlock it to set the wash cycle?
I am not sure if this dishwasher does have a lock mode. See this manual.
It is possible to use the Cancel button to get it out of the unknown state.
Alternatively turn the power off and on and see if there is any difference.
Feb 13, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher won't work heat lock light on how do
some dishwashers have a "lock out" mode so kids don't accidentally turn on. Normally, by pressing and holding the button for 5 seconds, it should turn it off.
Apr 07, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
I have a Frigidaire built in dishwasher that won't start. There is a light on by the 3 second lock button
Your dishwasher is in the lock mode. If you press the button on the dishwasher that has the lock for maybe 5 seconds , the light will go off. Then put the dishwasher in a wash cycle (normal) and your dishwasher should start up working. Make sure the door is all the way closed. Hear the click of the door when it shuts. After about 90 seconds it should have water in it, press the start/cancel button 2 times and the water drains out.
Jul 30, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Lock mode
TRY UNPLUGGING AND REPLAUG AFTER AFTER 12secs
Feb 07, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
23 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
