Question about Cambro 75CW148 Camwear Cup
Lid for 75cw148
What company makes a disposable lid that will fit Camwear 75cw148?
I NEED A NEW LID, CAN I GET IT REPLASTED
I have found that 90% of canister Ice cream makers are modeled the same, I have had a Back to Basics, Rival and West Bend Ice cream makers and the lids are interchangeable.
A lot of companies don't make replacement parts so I usually go with the West Bend lid. The first thing you will want to do if find the brand on your Ice Cream maker (usually found on the motor/top) and see if the manufacture does make replacement parts for your machine. If they do not have parts available I would try the West Bend Ice Cream maker lid U66-2, like i said it is a pretty standard size and will fit most Ice Cream Canisters.
Here is a link to West Bends part page: IC10885 Ice Cream Maker
The lid is very inexpensive so even if it doesn't fit your not throwing away a lot of money.
-Colleen @ Mending Shed
Apr 19, 2015 | Ice Cream Makers
I have lost the clear Canister lid and cap. Can I get a replacement
Need lid for sanyo slow cooker esc 450
When my lid was accidently broken years ago I found a heavy glass saucepan lid at a second hand shop that fitted it. A lid off a casserole dish of similar size would work just as well. Ensure you measure the inside width dimensions without lip and then including lip so you find a lid with a secure fit. Good luck.
Jun 17, 2013 | Sanyo Crock Pots & Slow Cookers
What is the velcro that came with my toto tank lid used for?
it is used to soften the lid to tank and keep it from rocking and china from rubbing
Mar 15, 2013 | Toto TCU974CRE-12 Toilet Tank Lid with...
Lid doesn't fit tight
put aluminum foil around lid and press onto pot this will help it make tight fit
Jun 12, 2012 | West Bend 84496 6-Quart Slow Cooker
I CAN'T GET THE COVER OFF THE PUMP STRAINER BASKET. I WAS TOLD THERE WAS A TOOL THAT FITS OVER TO MAKE IT EASIER.DO YOU KNOW OF IT
http://www.epoolshop.com/hayward_super_ii_pump_parts.aspx?variation=13732
It depends on the lid, the threaded lid on hayward can use two types of lid wrenches. One is the one made by hayward, the other is a metal wrench made my the pool tool company. Check out the link about to see if that would work.
Oct 24, 2010 | Hayward BASKET STRAINER OEM B207
Washer gets to spin cycle and stop
95% of the time, it is your lid switch.
The part that the lid makes contact with when it is closed (Litle plastic peice)
Depending on your make, Your can put a small pen in the hole and push down to verify if the piece is broken or it may be in the back part of your lid built into the back hinge.
Most local Appliance parts companies can get that part they just need the model and sometimes the serial number.
If you don't have any close you can usually get lid switch from these companies.
http://www.partselect.com/ or http://www.repairclinic.com/
Good Luck!
Nov 09, 2009 | Frigidaire Washing Machines
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
5 qt Slow Cooker Lid
That's a Durabrand crockpot, made for Wal-Mart if I remember correctly. I know that many of Durabrand's electronic products are made by a company called Funai, but I don't know who makes the cookware. I came up empty trying to find a manufacturer or parts source on the Internet.
Some suggestions:
1. Try Wal-Mart and see if they can tell you what they do with defective returns. Maybe they can give you a name to try, or maybe they'll have a dud unit they can give you the lid from.
2. Measure the lid and see if there's a close match to a lid from a name-brand cooker. You might find one that fits well enough.
3. Check your local Craig's List postings or your local sales flyer (Green Sheet, Pennysaver, whatever it's called in your area). You may find someone selling one for a few bucks, or you can ask if anyone has a lid.
Sorry I can't be more helpful, but maybe one of these will get you in the right direction. Thanks for asking here!
Aug 15, 2008 | Rival SCC658-SS 6.5-Quart
Replacement lid for Ultrex
Please keep in mind that the brand Ultrex was sold by The Home Shopping Network, not QVC.
Nov 16, 2007 | Rival 38601 Smart Pot 6-Quart
Cambro 75CW148 Camwear Cup Logo
328 people viewed this question
Top Cambro Home Experts
Donni Steen
Tom Chichester
Are you a Cambro Home Expert? Answer questions, earn points and help others
