Question about tracfone.com
How do I use speed dial numbers?
I was able to assign single digit speed dial numbers, but cannot figure out how to use them? Any suggestions?
  • 3 more comments
  • kakima Mar 19, 2014
    What make and model phone?
  • Loretta Feldman
    Loretta Feldman Mar 19, 2014
    That would help wouldn't it - MOTOGO EX431G
  • "Doc" Mar 19, 2014
    Press the key to make a new call (usually a green phone icon). Press the number you have assigned ("2", "6", etc. Press the "Call" button and the phone should take it from there, presuming you correctly programmed the speed dial number.
  • Loretta Feldman
    I have the Motogo EX431G and it has the symbol for contacts, but not one for outgoing call.
  • Loretta Feldman
    Loretta Feldman Mar 20, 2014
    Sorry - that didn't work.
  • 41 Answers
"Send" + (Number you assigned for the contact you want to call) + "Send" ... If that doesn't do the trick, refer here:
http://tracfone.deviceanywhere.com/tracfone/tutorial.seam;jsessionid=15A6CB0C590DEE9C662FC22CDB08FED0?tutorialId=20101&deviceId=904&cid=2282615&conversationPropagation=end
Posted on Mar 19, 2014
Testimonial: "NO - it just goes through the basics of making a call - I got that. I would like to use the speed dial numbers."
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
How of you set up speed dial?
We cannot help you unless we know the correct model/platform of your phone. In general
In nokia phones, you can call 1-9 and it will ask "speed dial not assigned. do you want to assign it now?". Select yes, and now you can add a contact to that speed dial number. Note that usually, digit O in speed dial is reserved for voice mailbox number.
Nov 28, 2012 | Cell Phones
I cant figure out how to set up speed dial?
Go to your phone call settings and activate speed dials feature.
Then come back to your phone in normal display mode,press and hold any desired digit e.g 2,3,4,5,6,7 on the key pad and follow the prompt for assigning of phone nos for speed dialing.
Sep 14, 2009 | Lands Phones
Nokia 1100 speed dial problem
hi,
1.Take your phone 2.Click menu 3.Go to contacts by scrolling down 4.Go to speed dial
There we can assign the number as speed dial.
May 21, 2009 | Nokia 1100
How to enter phone numbers into the memory/speed dial?
The manual from the GE web site is here:
http://www.home-electronics.net/ge/pc/IB/29267GE3_IB.pdf
It's a pretty straightforward process, Pick up the handset press STORE a location (0-9) STORE dial the number STORE
With only 10 storable numbers it's pretty thin, but you also have the last 50 CID numbers to dial. If you live in an area with more than one local area code (overlays) and mixed 10 digit dialing, it looks like you may have some programming to do to make it dial CID numbers properly.
Carl
Apr 21, 2009 | GE 29267 Corded Phone
Nokia 6085 how to speed dial
To assign a number to a speed dialing key, select Menu > Address Book > Speed
dial list, and scroll to the speed-dialing number that you want.
Select Assign or, if a number has already been assigned to the key, select Options >
Change. Select Find and the contact you want to assign. If the Speed dialing function
is off, the phone asks whether you want to activate it
FOR MAKING CALL
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number
in either of the following ways:
• Press a speed dialing key, then the call key.
• If Speed dialing is set to On, press and hold a speed-dialing key until the cal
Dec 22, 2008 | Nokia 6085 Cellular Phone
Krzr speed dial numbers
First, go to Menu. Then, number 4. Speed Dials. Then, if you wish to move your numbers around, simply click on a filled up speed dial slot you wish to change. It will take you to an Unassigned number, where you will click again. Then, there is an open spot where the name you just moved was. Find the name you want to be there, click, and scroll up to find the empty slot, then click.
Dec 07, 2007 | Cell Phones
Speed Dialing
hold the number that you assigned untill you see the number of the person (hold about 2 sec) when the number shows up press talk botton
Oct 19, 2007 | Uniden TRU9485 Cordless Phone
Setting up a speed dial
from the website:
How do I set speed dial for one of my contacts? First, find the contact in your Contact List, highlight it, and press OK. Then select Options -> Speed Dialing and press OK.
Choose one of the numbers from the list and select Assign to assign it to your contact. You can now use 1-Touch Dialing for that phone number. Just press and hold that assigned one or two digit number instead of dialing the contact's entire phone number.
Sep 16, 2007 | Kyocera K10 Royale Cellular Phone
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
tracfone.com Logo
101 people viewed this question
Top tracfone.com Computers & Internet Experts
Andrew Taylor
Andrew Taylor
CrisO
Are you a tracfone.com Computer and Internet Expert? Answer questions, earn points and help others
